Yeah that's the camp I fall in for engine break in, but everyone has their own methods. I actually had a guy at a stoplight scold me for not following proper procedure for break in once.
General Mechanics Question: lubed threads
Originally posted by natemoen View PostYeah that's the camp I fall in for engine break in, but everyone has their own methods. I actually had a guy at a stoplight scold me for not following proper procedure for break in once.Cy
Further on the ride it break-in; don't just go for a nice freeway ride. You want there to be lots of compression during break-in. You want to accelerate and decelerate (engine brake) hard. Break-in is fun, just be mindful of engine temps as the added friction is creating more heat than normal.'81 XS1100 SH
Sep. 12th 2015
RIP
Yeah, I will usually cruise around city streets in 1st or 2nd (depending on speeds) and just run the rpms up, let off and coast down, and repeat several times. Go for a short steady drive, the repeat the first step and then a calm short drive home and change the oil.
Break it in like you drive it.Nathan
Originally posted by 81xsproject View PostFurther on the ride it break-in; don't just go for a nice freeway ride. You want there to be lots of compression during break-in. You want to accelerate and decelerate (engine brake) hard. Break-in is fun, just be mindful of engine temps as the added friction is creating more heat than normal.Former owner, but I have NO PARTS LEFT!
Originally posted by natemoen View PostYeah, I will usually cruise around city streets in 1st or 2nd (depending on speeds) and just run the rpms up, let off and coast down, and repeat several times. Go for a short steady drive, the repeat the first step and then a calm short drive home and change the oil.
So it's not about taking the RPM's up high and then low, but rather bringing the combustion chamber pressures to their highest, as this is what actually seats the rings.Cy
Originally posted by DAVINCI View PostHow does one be mindful of engine temps?
(this is actually talked about by the author)Cy
Even first gear at full throttle is being pretty fast! I already have enough tickets......Nathan
Gotta do what ya gotta do to get the job done
:PNathan
Originally posted by natemoen View PostEven first gear at full throttle is being pretty fast! I already have enough tickets......
Have you ever watched what Honda does with EVERY new bike now? They do a chassis dyno full throttle run on every bike before it goes into the crate. I'm betting that's because that does most of the ring setting right there. The showed it on HD theater last year sometime.Cy
It only takes a second to get a ticket.
What do you think I meant by run the rpms up, when I run them up i usually get.right up thee.Nathan
Originally posted by natemoen View PostIt only takes a second to get a ticket.
What do you think I meant by run the rpms up, when I run them up i usually get.right up thee.Cy
Originally posted by cywelchjr View PostBefore the FD swap, I had to be careful of full throttle. In first gear that would almost always bring the front end up at least a little.Nathan
Originally posted by natemoen View PostJust don't rock the throttle full open in one shot!
On that note, this is a moot point for Loho if the cylinder doesn't show any scaring when he pulls the head. The rings will stay seated if they were already seated and the jugs don't get pulled off.Cy
