General Mechanics Question: lubed threads
  • petejw
    • 2269
    • sydney australia
    #46
    hey cy,
    its what i was taught at tech, and have done engine rebuilds
    in the past al be it was a few years ago,
    but each to there own,
    was only throwing it out there.
    ive also noticed valvoline make a running in oil
    its 30 weight mono, but i dont kno wat the difference would
    be compared to the standard 30 weight oil.
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    • cywelchjr
      XS-XJ Super Guru(Deceased)
      • 4450
      • Sacramento, CA
      #47
      I remember being told that way back in High School as well, but I also remembered having been told different later. Last time I looked, I couldn't even FIND an oil that I would feel comfortable putting in one of these engines in a single grade non-detergent oil. But then there are a lot of things the rest of the world (and even the U.S.) gets that we in Kalifornia can't get/have access to. We get crappy paints and stuff like that, because it's worse for us than for anybody else, so we have to use paints that don't last more than a few years (that's why even in the old days nobody wanted a camaro made in the Ca plant, the paint was junk and would delaminate and fade badly).
      • petejw
        • 2269
        • sydney australia
        #48
        ill be doing a top end rebuild in a few weeks,
        and be buying the running in oil, when i get it
        ill check it out and see what the differences are if any.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • petejw
          • 2269
          • sydney australia
          #49
          might not have been just the detergents, the other thing is that it also has no
          friction modifiers in the oil at all.
          just did a quick search
          penrite also does a running in oil
          but theyve changed the viscosity to 15-40
          heres a link if ur interested
          For nearly 100 Years, Penrite has served the lubricant market in Australia with products such as engine oils, automatic transmission fluids, gear & differential oils, coolants, greases, heavy-duty engine, hydraulic & industrial oils, farm and construction products
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
            #50
            I saw at ace hardware they have some non detergent mono grade oils. Been a few weeks since I looked but I think they had 20 30 and 40. They weren't air tool and compressor oils either.
            • acof911
              • Jun 2005
              • 244
              • S.E PA
              #51
              Lubed Threads
              I use this on just about everything - Anti-Seize.
              • cywelchjr
                • 4450
                • Sacramento, CA
                #52
                http://www.penriteoil.com.au/searchresults.php
                Shouldn't be using anything with friction modifiers on these bikes anyways, it's gonna have a really high chance of causing clutch slippage.
                • LoHo
                  • Sep 2002
                  • 1342
                  • Fresno, CA
                  #53
                  Loose screw
                  Here's a small screw and washer from the right hand controls after bouncing around in the cylinder:
                  Here's the head after forging that screw into a lump:
                  Here's the top of the piston:
                    #54
                    Ouch! That sucks man!
                    • LoHo
                      • Sep 2002
                      • 1342
                      • Fresno, CA
                      #55
                      Sucks, yeah, but not as bad as it might have. The cylinder walls are OK. I think I can wire wheel the head a little and put it back together when I get my gaskets. I'm going to try the cam chain tensioner replacement again. I might swap on the HD mufflers I bought eight years ago as well, since the exhaust is off the bike.
                      I have no idea how I got the screw in there, but I remember having to find a screw from a partzer I have when I repaired the cut-off switch. My wife says I should try out for "Minute to Win It", as they specialize in launching tiny parts into tiny holes from a distance. Apparently that is a hidden skill I have.
                        #56
                        You might be ok for a time but I would bet eventyally your going to get hot spots that develope and eventually burn a hole in the piston, head might me ok but same thing could happen. I would start looking for a new set of piston and a cheap head.
                          Ouch!.......could very carefully dremal the high spots.........or could pull the cyl......then seeing glazed over rings and looking kinda wrung out, figure what the heck..........big bore time........................and then it begins............to be continued...........
                            You know, that is not the way I would tap the threads for the 8 sparkplug performance mod but it does look pretty spectacular; almost the same as what happened to my Toyota engine.
                            • petejw
                              • 2269
                              • sydney australia
                              #59
                              that sux, but like u said couldve been much worse,
                              u might also want to check the valve seats and valves
                              by pouring fuel in the ports and check for seapage/leaks.
                              depending on what u want to do with the bike (keep it or sell it)
                              and how much money you want to spend on it, you could probably
                              clean it up and get away with it for a bit.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
