Hmmm. I found it in their website now (i swear I didn't before).
TC SOFA experience (so far)
Theodore Roosevelt -
BDF Special
Dyno tuned to 98 hp at the rear wheel.Comment
Yeah when I was looking before I tried all their prefix letters and never had anything come up. No one has had them either anyways.Nathan
Theodore RooseveltComment
The tech tip and instructions I read state (I believe) the 6117 IIRC. I had no trouble finding that one as it's the filter used by the 98-07 (I believe) GL1500 of which there are thousands on the road. I think the one you mention is a wider auto filter which was mentioned as going into bypass at a lower pressure than the bike filter (all the MC filters I have see from gram start with 6 as the first digit).
Ps: just checked, it's PH6017A that is mentioned. The one you reference is an auto filter used by the rivco adapter and the SOFCA.Last edited by cywelchjr; 01-25-2011, 06:26 PM.Cy
If you get desperate there are many online stores that sell them .We pay 6 bucks for them up here. One example!!!
BDF Special
filter
The fram PH6017A can be had at WallyWorld if that is one of the options. Same as my ST uses and several others besides the Wing. Oem honda filter cost me bout $7 whenever I occassionally use an OEM one.Last edited by motoman; 01-25-2011, 06:52 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Yeah, the 6017A according to the tech tip and instructions is the filter the adapter was made for. The other filter is for the one that replaces the oil cooler assy at the same time, has to do with how it mounts VS the one I have.
An update, after two round trips yesterday. I checked after I pulled into the garage, and everything is clean and dry. So now it's wait a see how things are at the next oil change, assuming nothing fails in between, which I'm not expecting.
I have to say, I'm really impressed with the quality look of the thing, it looks like something run off an assembly line, with the sole exception of not being anodized.Cy
Hey there Nate/Cy,
Nate has the SOF"C"A, and so needs the larger/wider designed 3950 or equivalent type filter, vs. the smaller diameter 6017 for the SOFA.
I believe it was Toolmaker Tim that found out that the Fram 6607 will also fit the S, is a bit shorter to allow more clearance but has the same ID for the oil ring seal...which is one of the important parameters for finding one to fit. The oil supply holes are just inside the 2.4" diameter zone, so the Oring needs to be very close to that zone.
**Just checked Fram, the 6607 has an ID for the oil seal ring of 2.27", a little bit shy of the 2.4", however I've tried to machine that opening a bit closer to the nut, and it might be a little smaller in diameter on your plate, you may need to take a ruler/caliper and check it's position and relative diameter ring size to see if the 6607 would extend beyond the opening without covering/closing or restricting it!?
The other parameter is the 20mm x 1.5 pitch threading.
I didn't actually design the SOFCA around the filter, but found a filter that would allow the design of the SOFCA to work with it's larger/wider securing nut.
Cy, glad to hear that you've had a successful install so far.
I've had several inquiries regarding both items, and I'm planning on putting more into production, once the garage THAWS out a little more!!
PS, go to this link:
Then click on the PH3950, and then at the bottom you will see a very long list of COMPETITOR's FILTERS Cross Referrence...should help you find one in a brand close to you!
So your saying that the 6607 MIGHT work for the SOFCA?Nathan
Now see what happens when you miss ONE little character in an entire message?
Here I even looked it up and all, and didn't catch that as I was saying that filter was the right one for the SOF*C*A that it was that device he has. So I guess Nate can slap me around for stupid for a while now (I'm sure he's gonna have fun with it).
PS, the new design of the SOFA sure looks like it's a good bit sturdier as comes to applying the pressure of the center out to the edges being as it looks meatier than the pictures of the original unit. Any feedback on if that made failed installs any less likely?Cy
I have left it alone this long (i did kinda hijack your thread anyways). I will save the barrage of insults for another time and another place....Now see what happens when you miss ONE little character in an entire message?
PS, the new design of the SOFA sure looks like it's a good bit sturdier as comes to applying the pressure of the center out to the edges being as it looks meatier than the pictures of the original unit. Any feedback on if that made failed installs any less likely?Nathan
What is exactly a SOFCA other than it looks to be a spin on filter converson, and what does it look like?
'79 XS11SFComment
☮Comment
thanks phil may be a thought to do on mine later on but I don't find it all that messy or hard to take off. Filters are a little expensive at $10.00 for the fram.'79 XS11SFComment
There's the convience of being able to walk into any parts supller and buy an oil filter when you do this mod. Messy is one of the reasons I did it and I find oil changes are faster and easier. A Fram PH3950 or the Canadian Tire cross reference can be had for around $6.00.
Like I have mentioned before I have been able to find Quaker State oil on sale with a free Fram oil filter for $14.99 for 5 litres at Canadian Tire here in Canada. So it's also cheaper to do oil changes with this mod too.BDF Special
