new member new bike need some tech help/ advice
  • proddy2008
    • Nov 2010
    • 25
    Hm tpi fuel pump is 4 to 6 amps
    bikes:
    99 tl1000
    96 honda 250 nighthawk
    77 xs750 special
    suzuki 350
    current project:
    1979 xs 11 special
      Most people switch all the dash, tail, turn, and brake lights over to LED that saves a lot of juice. Headlight on low is about 5 amps high is about 6 amps. I think the current setup of TCI and coils is about 10 amps (I might be a little generous with that number not sure really) total so I would think the MS and the COP would probably be about the same maybe.
      So even if you did all LED and so we estimated about 17 amps normally needed just to run things you would have 7 to spare and then you still have to figure in amps to charge the battery.
      Just remember Watts divided by volts gives you amps.
      • proddy2008
        • Nov 2010
        • 25
        That sounds about normal for how close i usualy cut it lol optima battery and trickel charger are sop for anything i build anyways lol now the trouble will be figuring out a shop that will take the dive and help me out when im gone
        bikes:
        99 tl1000
        77 xs750 special
        suzuki 350
        current project:
        1979 xs 11 special
        • proddy2008
          • Nov 2010
          • 25
          #34
          Aperently there is a 6000k headlight for harlys that only draws 1.75 amps that wud b cool
          bikes:
          99 tl1000
          77 xs750 special
          suzuki 350
          current project:
          1979 xs 11 special
            #35
            Yup. HID headlights are another option. I want to do that myself.
            • proddy2008
              • Nov 2010
              • 25
              #36
              So anything other than ignition i will be looking for lowest currentvdraw possible i wonder which pulls lesd hid or led or maby something i havent heard of can florecent fit lol
              bikes:
              99 tl1000
              77 xs750 special
              suzuki 350
              current project:
              1979 xs 11 special
                #37
                LED is going to be the lowest current draw. As far as I know there is not s DOT legal headlight. So HID headlight would be the way to go.
                • proddy2008
                  • Nov 2010
                  • 25
                  #38
                  Il probly go with led then as long as u can see it at 200 ft its fine
                  bikes:
                  99 tl1000
                  77 xs750 special
                  suzuki 350
                  current project:
                  1979 xs 11 special
                  • proddy2008
                    • Nov 2010
                    • 25
                    #39
                    Turns out an led headlight will actualy need 2.5 amps for just the low beam hid seems the way to go
                    bikes:
                    99 tl1000
                    77 xs750 special
                    suzuki 350
                    current project:
                    1979 xs 11 special
                      #40
                      And they will ne way brighter. Most people switch to hid for the brightness and the power saving is just a benefit.
                      I want to go hid and then still add a pair of driving lights on my case guards.
                      • proddy2008
                        • Nov 2010
                        • 25
                        #41
                        Yeah hid headlight then led tail and blinkers will give me a safe margin for charging and everyrhing with the efi problem solved now to find a shop that will do it
                        bikes:
                        99 tl1000
                        77 xs750 special
                        suzuki 350
                        current project:
                        1979 xs 11 special
                        • proddy2008
                          • Nov 2010
                          • 25
                          #42
                          Just found out that i can add msiiix ans have sfi cop and usb conection also sd card for dataloging ...... sweeet
                          bikes:
                          99 tl1000
                          77 xs750 special
                          suzuki 350
                          current project:
                          1979 xs 11 special
                            #43
                            I was thinking, you should be able to do this with a crank sensor (the pair cylinders at exactly in time with each other) and then a hall effect sensor for TDC of #1 on the cam, which may be able to be inside the valve cover as long as you get something that can take the oil. I mean most auto engines use both cam and crank sensors.
                            • proddy2008
                              • Nov 2010
                              • 25
                              #44
                              Thats the general idea up until this point though the ms was unable to do sfi so im exited now the upgrade also offers a bunch of others the cam signal needs a wheel on the cam itself im thinking of just geting the end lengthened then put an ls1 cam gear on the end to get the signal then a 36-1 trigger on the crank
                              bikes:
                              99 tl1000
                              77 xs750 special
                              suzuki 350
                              current project:
                              1979 xs 11 special
