Hm tpi fuel pump is 4 to 6 amps
new member new bike need some tech help/ advice
Most people switch all the dash, tail, turn, and brake lights over to LED that saves a lot of juice. Headlight on low is about 5 amps high is about 6 amps. I think the current setup of TCI and coils is about 10 amps (I might be a little generous with that number not sure really) total so I would think the MS and the COP would probably be about the same maybe.
So even if you did all LED and so we estimated about 17 amps normally needed just to run things you would have 7 to spare and then you still have to figure in amps to charge the battery.
Just remember Watts divided by volts gives you amps.Nathan
That sounds about normal for how close i usualy cut it lol optima battery and trickel charger are sop for anything i build anyways lol now the trouble will be figuring out a shop that will take the dive and help me out when im gonebikes:
99 tl1000
96 honda 250 nighthawk
77 xs750 special
suzuki 350
current project:
1979 xs 11 special
Yup. HID headlights are another option. I want to do that myself.Nathan
LED is going to be the lowest current draw. As far as I know there is not s DOT legal headlight. So HID headlight would be the way to go.Nathan
And they will ne way brighter. Most people switch to hid for the brightness and the power saving is just a benefit.
I want to go hid and then still add a pair of driving lights on my case guards.Nathan
Originally posted by proddy2008 View PostJust found out that i can add msiiix ans have sfi cop and usb conection also sd card for dataloging ...... sweeetCy
Thats the general idea up until this point though the ms was unable to do sfi so im exited now the upgrade also offers a bunch of othersthe cam signal needs a wheel on the cam itself im thinking of just geting the end lengthened then put an ls1 cam gear on the end to get the signal then a 36-1 trigger on the crank
bikes:
99 tl1000
77 xs750 special
suzuki 350
current project:
1979 xs 11 special
