XV920 Float Valve Mod
  • #16
    Originally posted by TopCatGr58 View Post
    Just for an aside, the wires on the float valves are also there to help the float PULL the valve open in case it gets stuck and won't open from just gravity and fuel pressure, when the float finally drops low enough to engage the wires.
    Good point TC. I hope they arrive by mid week.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • #17
      These needle valves arrived today and I just installed them. Vac test was perfect. There is now no leakage what so ever. So now I can set the floats and put this leaky needle valve issue aside hopefully once and for all. I will be ordering another set of these for my hope up bike.
      Rob
      1978 XS500E
      1981 Suzuki GS1100
      • #18
        I always advice folks not to use the washers on the new ones and opt for fuel thread tape instead. It will keep you from having harsh bends on the tabs.
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • #19
          I was actually curious as to whether I should use the metal washers that came with the new valves or the fiber type that are stock with the original valves. I opted to use the metal ones and didn't even have to adjust my float heights. They do not look like they will bind within they movement range.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
