It seems Parts n More has changed their website. I went there with the intention of getting a set of XV920 float valves for my 79F and couldn't find anything. Bike Bandit is living up to their name by asking $90+ for their valve. Anybody know where I can find the blasted things at for a sane price?
XV920 Float Valve Mod
Was that $90 per valve, or $90 for a set of four?
Try Z1 Enterprises: $20.48 per carb kit
http://www.z1enterprises.com/detail.aspx?ID=500"Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)
Z1 also sells just the XV920 float valves at $10 apiece plus shipping, Georgefix can also get them, he quoted me $12 a piece plus shipping. Have not checked into the shipping cost, but I'll probably order from George as he has treated me well on other things and is easy to deal with. JMOLife is what happens while your planning everything else!
Did you. Try not clicking your year on pnm? When I entered 79 f I got nada but if you looke before 78 there is a link to just xs1100 click on it.u" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing
Z1 Enterprises
Ok, I dug up my receipts for my other XV920 valve seats and they did come from Z1. I got my plastic floats from Mikes XS at the same time. Prom, those seats were $90 each.Now that I have tried using Parts n More's new site, I have decided it's more trouble than it's worth. I liked it better when you could just click on your bike and it took you right to it. JMO
1979XS1100SF
K&N's and drilled airbox
Jardine 4in1
Dunlop Elite 3's
JBM slide diaphragms
142.5 main jets
45 pilot jets
T.C.'s fusebox & SOFA
750/850 FD mod.
XV 920 Needle Mod.
Venture Cam Chain Tensioner
Holy Batguano Bat man!!!! $90 per valve seat!!!!! Sorry, but that is well...amazing!!! I just ordered 4 of them plus 6 jets from Georgefix for $60 total. Liek I said, I priced them at Z1 at $10 per, plus shipping which I never confirmed from them.Life is what happens while your planning everything else!
Wow, Parts n More really did work that site over. I wonder what possessed them to change the place that much. That really didn't seem to be much of an improvement.
Maybe they changed their web host.RIP Whiskers (Shop Boss) 25+yrs
Everything on hold...
I want to do this mod
http://www.z1enterprises.com/Float-N...J750-2560.aspx
Is this what I need.
TIA
RickXS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
XS1100SG Project bike
XV920 valves
Yes, them's the ones. Some have said that the metal seal washer made it hard to set the float height correctly due to excessive bending for the tabs on the float. I didn't have a problem on either of the carb sets I did. The feed hole is a little smaller, but it hasn't caused me any problem. Not having to worry about fuel in your oil is nice. I forgot to shut off my petcocks for several days and didn't leak a drop.1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
thanks TimXS1100F TKAT fork brace Stock suspension. Vetter Fairing. Pingel Petcocks. Geezer voltage regulator
650SF
Got 4 coming from Georgefix at 10 a pop plus shipping
RobKEEP THE RUBBER SIDE DOWN
1978 XS1100E Modified
1978 XS500E
1979 XS1100F Restored
1981 Suzuki GS1100
1983 Suzuki GS750S Katana
1983 Honda CB900 Custom
Originally posted by Toolmaker Tim View PostYes, them's the ones. Some have said that the metal seal washer made it hard to set the float height correctly due to excessive bending for the tabs on the float. I didn't have a problem on either of the carb sets I did. The feed hole is a little smaller, but it hasn't caused me any problem. Not having to worry about fuel in your oil is nice. I forgot to shut off my petcocks for several days and didn't leak a drop.
1978 XS500E
1981 Suzuki GS1100
Rob, the wires across the top are there for alignment. I am sure they would work without them, however, I typically hang the valve on the float by that wire and lower them into the seat as a unit.Life is what happens while your planning everything else!
Wires
+1 on what Don said. I took mine off on both of the rebuilds I did. I just made sure the limiter tab was set so the needle wouldn't get misaligned if the bowls ran dry.1979XS1100SF
Jardine 4in1
Dunlop Elite 3's
142.5 main jets
45 pilot jets
750/850 FD mod.
XV 920 Needle Mod.
Just for an aside, the wires on the float valves are also there to help the float PULL the valve open in case it gets stuck and won't open from just gravity and fuel pressure, when the float finally drops low enough to engage the wires.
T.C.T. C. Gresham
