XV920 Float Valve Mod
  • XV920 Float Valve Mod
    It seems Parts n More has changed their website. I went there with the intention of getting a set of XV920 float valves for my 79F and couldn't find anything. Bike Bandit is living up to their name by asking $90+ for their valve. Anybody know where I can find the blasted things at for a sane price?
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    Was that $90 per valve, or $90 for a set of four?
    Try Z1 Enterprises: $20.48 per carb kit
    http://www.z1enterprises.com/detail.aspx?ID=500
      Z1 also sells just the XV920 float valves at $10 apiece plus shipping, Georgefix can also get them, he quoted me $12 a piece plus shipping. Have not checked into the shipping cost, but I'll probably order from George as he has treated me well on other things and is easy to deal with. JMO
        Did you. Try not clicking your year on pnm? When I entered 79 f I got nada but if you looke before 78 there is a link to just xs1100 click on it.u
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        mikes650 front fender
        led's gallore...
        renthal bars
        gold valve emulators
        vmax tensioner
        Rifle fairing
          Z1 Enterprises
          Ok, I dug up my receipts for my other XV920 valve seats and they did come from Z1. I got my plastic floats from Mikes XS at the same time. Prom, those seats were $90 each. Now that I have tried using Parts n More's new site, I have decided it's more trouble than it's worth. I liked it better when you could just click on your bike and it took you right to it. JMO
          1979XS1100SF
          Jardine 4in1
          Dunlop Elite 3's
          142.5 main jets
          45 pilot jets
          750/850 FD mod.
          XV 920 Needle Mod.
            Holy Batguano Bat man!!!! $90 per valve seat!!!!! Sorry, but that is well...amazing!!! I just ordered 4 of them plus 6 jets from Georgefix for $60 total. Liek I said, I priced them at Z1 at $10 per, plus shipping which I never confirmed from them.
              Wow, Parts n More really did work that site over. I wonder what possessed them to change the place that much. That really didn't seem to be much of an improvement.
              Maybe they changed their web host.
              Everything on hold...
                I want to do this mod
                http://www.z1enterprises.com/Float-N...J750-2560.aspx
                Is this what I need.
                TIA
                Rick
                650SF
                XS1100SG Project bike
                  XV920 valves
                  Yes, them's the ones. Some have said that the metal seal washer made it hard to set the float height correctly due to excessive bending for the tabs on the float. I didn't have a problem on either of the carb sets I did. The feed hole is a little smaller, but it hasn't caused me any problem. Not having to worry about fuel in your oil is nice. I forgot to shut off my petcocks for several days and didn't leak a drop.
                  1979XS1100SF
                  Jardine 4in1
                  Dunlop Elite 3's
                  142.5 main jets
                  45 pilot jets
                  750/850 FD mod.
                  XV 920 Needle Mod.
                    thanks Tim
                    650SF
                      Got 4 coming from Georgefix at 10 a pop plus shipping
                      Rob
                      KEEP THE RUBBER SIDE DOWN
                      1978 XS1100E Modified
                      1978 XS500E
                      1979 XS1100F Restored
                      1981 Suzuki GS1100
                      1983 Suzuki GS750S Katana
                      1983 Honda CB900 Custom
                        can the wires that go over the top be removed or is having them attached to the floats part of what makes them work better?
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • #13
                          Rob, the wires across the top are there for alignment. I am sure they would work without them, however, I typically hang the valve on the float by that wire and lower them into the seat as a unit.
                          • #14
                            Wires
                            +1 on what Don said. I took mine off on both of the rebuilds I did. I just made sure the limiter tab was set so the needle wouldn't get misaligned if the bowls ran dry.
                            1979XS1100SF
                            Jardine 4in1
                            Dunlop Elite 3's
                            142.5 main jets
                            45 pilot jets
                            750/850 FD mod.
                            XV 920 Needle Mod.
                            • #15
                              Just for an aside, the wires on the float valves are also there to help the float PULL the valve open in case it gets stuck and won't open from just gravity and fuel pressure, when the float finally drops low enough to engage the wires.
