Help if you can, or trip is cancelled...
  • randy
    • Dec 2003
    • 4521
    Originally posted by CA
    Randy, actually that was reading directly from the coil itself. the orange and gray wires complete the circuit and read 11.7 if I remember correctly. All I know is the coil "negative," opposite the positive line reads 1.7. I just thought that was strange.
    CA,
    Actually, you've got that a bit upside-down. The red/white is the positive lead to both coils. The gray and the orange are the negative that go to the TCI. The TCI grounds them intermittently to fire the coils.
    • CA
      • Feb 2009
      • 267
      • Nashville, TN
      Right those were the words in my head that didn't translate to my fingers ha. jk.
      I am bad about articulating electical issues. That's what you get from a divinity school student!
      1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
      • CA
        • Feb 2009
        • 267
        • Nashville, TN
        How do you test ohms? I have a digital meter that does it all, but I can't get a reading on the four pronged thing at the tci box, but I have never done it before.
        Do I groung it then stick it in the plug?
        • randy
          • Dec 2003
          • 4521
          No, you test between the upper pair for one pickup, the lower pair for the other pickup. Value should be 720 Ohms +/- 20%
          Somewhere between 600 - 860 is OK.
          Oh, remove the plug from the TCI and test the plug, not the TCI
          • newc4
            • 598
            • Vienna VA
            If you still have your old coils swap in the good one. That would tell you if the problem is directly related to the coil.
            Enroute to XSEast my cylinders began dropping out after running through a cold fog but cleared as the weather did. Extra moisture facilitates shorting of coils.
            Darrell
            78E
            80G project
            06FJR
            • CA
              • Feb 2009
              • 267
              • Nashville, TN
              Yes I have have .744 on my K ohms reading for both pairs. hmmm
              btw: the recap is the starter turns it over but absolutely no ignition. I have spark but I guess not at the right time?
              • psycoreefer
                • Feb 2008
                • 1557
                • Minden, NV
                now remove the timing cover on the left side, put your probes back on one pair of the wires at the TCI plug and wiggle and gently pull the wires under the timing cover and see if your reading changes. If it does change you'll need to do the pickup wire fix. If not you've got the cover off so you might as well verify the timing.
                1979 xs1100 Special -
                My Bike:
                [link is broken]
                  Sorry if this has been covered before. If you changed the coils, or rewired the pickups or any of that, you might have the coils backwards. You can switch the connectors between the coils and see if that changes it.
                  • CA
                    • Feb 2009
                    • 267
                    • Nashville, TN
                    Those pickup wires are as solid as a rock!
                    Dgsxer that occured to me as well as it happened when I first installed them
                    THis just in. THe red "thicker" wire next to the orange wire on the tci plug is not providing any voltage. Not sure if it is supposed to . All other colored ones around it read a steady 9.4 (my battery is only at 11.3 because of lots of cranking!)
                    • CA
                      • Feb 2009
                      • 267
                      • Nashville, TN
                      Actually the rest read a 10.9...measured from the other side and got a better reading.
                      Im so glad my boss gave me a (fix you bike day)!
                      • randy
                        • Dec 2003
                        • 4521
                        Maybe this will help? Click on the pic to enlarge it for detail.
                        • psycoreefer
                          • Feb 2008
                          • 1557
                          • Minden, NV
                          Is it red/white or red/yellow? Red/white should only be "hot" when your cranking.
                          PS get that battery charged up - i'll never start with a weak battery!
                          My Bike:
                          [link is broken]
                          • CA
                            • Feb 2009
                            • 267
                            • Nashville, TN
                            Yes number 6. And I tried to crank it it it came alive.
                            Ha and that was my best guess!
                            Regardless, thanks for your sticking with me fellas!
                            • CA
                              • Feb 2009
                              • 267
                              • Nashville, TN
                              Can you spot the at least 1 difference?
                              (Sorry for the poor cell quality)
                              may be nothing but at least its fun!
                              • Ivan
                                • Jul 2008
                                • 2524
                                • Hutchinson KS
                                Hold the phone...
                                You say you had the trouble occur after switching to new coils? Are you 100 percent you didn't get the primary leads from the TCI swapped? Making the coils fire at the wrong time? Is your firing order right? Should be that one coil fires the middle cylinders and one fires the outter cylinders.
                                Sounds like it might be time to follow the mechanic's alphabet: ACBF (Always Check Basics First)
                                Hope it works out for you soon. These things can be such a pain.
                                Ich habe dich nicht gefragt.
