I believe the TCI gives up ataround 10.5V, actually. If it gave up at 12, it would die after idling for 30 seconds at a stop light, since the charging system kinda sucks on these bikes.
So, the TCI works on another bike and the coils both spark. Are you certain you aren't fighting a fuel starvation issue? If you're getting spark, and the TCI tested good, I am starting to think its something else.
Might even be worth it to pop the valve cover and check cam timing. And a compression check might be in order.
Of course it may be the turbo encabulator, you never know.
But once running I will look at how such rubbing got there.
