Help if you can, or trip is cancelled...
Right those were the words in my head that didn't translate to my fingers ha. jk.
I am bad about articulating electical issues. That's what you get from a divinity school student!
1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)Comment
How do you test ohms? I have a digital meter that does it all, but I can't get a reading on the four pronged thing at the tci box, but I have never done it before.
Do I groung it then stick it in the plug?1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)Comment
If you still have your old coils swap in the good one. That would tell you if the problem is directly related to the coil.
Enroute to XSEast my cylinders began dropping out after running through a cold fog but cleared as the weather did. Extra moisture facilitates shorting of coils.Darrell
78E
80G project
06FJRComment
Yes I have have .744 on my K ohms reading for both pairs. hmmm
btw: the recap is the starter turns it over but absolutely no ignition. I have spark but I guess not at the right time?1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)Comment
now remove the timing cover on the left side, put your probes back on one pair of the wires at the TCI plug and wiggle and gently pull the wires under the timing cover and see if your reading changes. If it does change you'll need to do the pickup wire fix. If not you've got the cover off so you might as well verify the timing.1979 xs1100 Special -
My Bike:Originally posted by fredintoonGoes like a train, corners like a cow, shifts like a Russian tractor, drinks like a fish, you are gonna love it.
[link is broken]Comment
Sorry if this has been covered before. If you changed the coils, or rewired the pickups or any of that, you might have the coils backwards. You can switch the connectors between the coils and see if that changes it.Life is what happens while your planning everything else!
78 XS750Comment
Those pickup wires are as solid as a rock!
Dgsxer that occured to me as well as it happened when I first installed them
THis just in. THe red "thicker" wire next to the orange wire on the tci plug is not providing any voltage. Not sure if it is supposed to . All other colored ones around it read a steady 9.4 (my battery is only at 11.3 because of lots of cranking!)1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)Comment
Is it red/white or red/yellow? Red/white should only be "hot" when your cranking.
PS get that battery charged up - i'll never start with a weak battery!1979 xs1100 Special -
Hold the phone...
You say you had the trouble occur after switching to new coils? Are you 100 percent you didn't get the primary leads from the TCI swapped? Making the coils fire at the wrong time? Is your firing order right? Should be that one coil fires the middle cylinders and one fires the outter cylinders.
Sounds like it might be time to follow the mechanic's alphabet: ACBF (Always Check Basics First)
Hope it works out for you soon. These things can be such a pain.Ich habe dich nicht gefragt.Comment
