When trying to remove the cover from the master cylinder on my '78 XS11 the brass inserts for the threads came out. Has anyone ever had this happen before and what did you do or what do you recommend? Thanks
Front Master Cylinder Problems
Theodore RooseveltTags: None -
Can you remove them from the screws and re-use them? Maybe a tiny dab of Gorilla glue on it will hold it in?1980 XS850SG - Sold
-H. Ford -
I have all of the screws off except one of them that I may have to drill out of the insert. I was sort of thinking JB weld to put them back in but I just wanted to see if anyone else has had this problem and if so what they did.Nathan
Theodore RooseveltComment
I have a 78 xs that I will be parting out soon. If you looking to replace the master cylinder instead of trying to repair it, send me a PM and let me know.
Thanks1980 xs1100g mostly. "Adrenalize - the Yamaha I always wanted to be able to order"
Modified frame, side covers, seat, back rest, engine, carbs, airbox, hoses, headlight assembly, turn signals, mirriors, handle bars, grips, v rated tires, gauges, homemade 4-2 exhaust system, leather upholstery, custom paint including True Fire Flames air brush work. A 25 year dream realizied.
"It ain't braggin if you can do it" Muhammad AliComment
'78E original ownerFast, Cheap, Reliable... Pick any two
"A man should look for what is, and not for what he thinks should be" Albert Einstien.Comment
☮Comment
I guess I will rough in holes up and glue the inserts in tomorrow night then. I wish I had a Special MC, that would make this much easier!Nathan
Ahh, but don't we all?!That 2-wheeled monster that calls to us from the driveway!
That's one thing I really like about the LH. The whole MC is solid metal, with a metal lid that screws on. No plastic reservoirs to deal with (front OR rear).Last edited by CatatonicBug; 05-03-2010, 09:47 PM.1980 XS850SG - Sold
-H. FordComment
That's one thing I really like about the LH. The whole MC is solid metal, with a metal lid that screws on. No plastic reservoirs to deal with (front OR rear).[/QUOTE]
Would it be possible to change over to a solid metal MC?Nathan
I usually use red loctite bearing set that will hold inserts. It is heat release."We are often so caught up in our destination that we forget to appreciate the journey." "Comment
-H. FordComment
