Front Master Cylinder Problems
    Originally posted by randy
    Umm....No, I have a Standard Master. The Special has that radical angle thing goin on...
    Ah, yet another year-to-year difference discovered. After looking at the parts fiche, what you have is a '80-81 standard master cylinder. The '78-79 have the brass inserts into the plastic for the cap and separate screws and a clamp to attach the reservoir to the body just like the rear one (in fact, the screws/clamp are the same). They don't show the reservoir, but the 80-81 screws are the same as the Specials.
    '78E original owner
      Strange, but on my '79 front M/C the screws go all the way through holes that are molded into the corners of the reservoir and thread into the M/C body. The rear does have the brass inserts though.
      Hey, Randy, do you remember that batch of replacement master cylinder reservoirs I took off of your hands a few years back? They fit onto standard M/Cs, but they had the brass inserts he is talking about. When I installed one onto one of my rides, I elected to drill through a couple of the inserts so two original screws would still go through to the body of the M/C. I just couldn't see myself relying on the friction fit of the square ring and gravity, to hold the replacment reservoir onto the body of the M/C. Perhaps natemoen has run into one of the reservoirs that you or I sold!
      • petejw
        • 2269
        • sydney australia
        this is a pic of my stock m/c,
        not sure if its the same as the midnites,
        but if it is, it can run both calipers at the front.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        1981 xs1100 RH (aus) (5N5)
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
