Front Master Cylinder Problems
    When trying to remove the cover from the master cylinder on my '78 XS11 the brass inserts for the threads came out. Has anyone ever had this happen before and what did you do or what do you recommend? Thanks
    Can you remove them from the screws and re-use them? Maybe a tiny dab of Gorilla glue on it will hold it in?
      I have all of the screws off except one of them that I may have to drill out of the insert. I was sort of thinking JB weld to put them back in but I just wanted to see if anyone else has had this problem and if so what they did.
      • randy
        • Dec 2003
        • 4521
        Strange, but on my '79 front M/C the screws go all the way through holes that are molded into the corners of the reservoir and thread into the M/C body. The rear does have the brass inserts though.
        • hightec_redneck
          • Apr 2010
          • 44
          • Elkton South Dakota
          I have a 78 xs that I will be parting out soon. If you looking to replace the master cylinder instead of trying to repair it, send me a PM and let me know.
          Thanks
          1980 xs1100g mostly. "Adrenalize - the Yamaha I always wanted to be able to order"
          Modified frame, side covers, seat, back rest, engine, carbs, airbox, hoses, headlight assembly, turn signals, mirriors, handle bars, grips, v rated tires, gauges, homemade 4-2 exhaust system, leather upholstery, custom paint including True Fire Flames air brush work. A 25 year dream realizied.
          "It ain't braggin if you can do it" Muhammad Ali
            You have a Special master; the Standard reservoir looks the same but has the brass inserts and 'clamps' to the MC body internally.
            '78E original owner
            • b.walker5
              • Feb 2009
              • 1745
              • Invercargill, New Zealand
              Kinda sounds a bit BDSM to me
              • XSokieSPECIAL
                • Jun 2009
                • 1631
                • Tulsa, OK
                WHAT?
                  Lol.
                    I guess I will rough in holes up and glue the inserts in tomorrow night then. I wish I had a Special MC, that would make this much easier!
                      Ahh, but don't we all?! That 2-wheeled monster that calls to us from the driveway!
                      That's one thing I really like about the LH. The whole MC is solid metal, with a metal lid that screws on. No plastic reservoirs to deal with (front OR rear).
                        That's one thing I really like about the LH. The whole MC is solid metal, with a metal lid that screws on. No plastic reservoirs to deal with (front OR rear).[/QUOTE]
                        Would it be possible to change over to a solid metal MC?
                        • Winterhawk
                          • Jun 2004
                          • 684
                          • Missouri
                          I usually use red loctite bearing set that will hold inserts. It is heat release.
                            Well, on the LH, the front MC only powers the front RIGHT caliper. The left is controlled by the rear MC. I would not trust the size of the LH MC to control 2 calipers.
                            • randy
                              • Dec 2003
                              • 4521
                              Umm....No, I have a Standard Master. The Special has that radical angle thing goin on...
