Hey guys 5 hours later and I need help please?
  • Suckerpunch
    • Apr 2010
    • 116
    • Portland Oregon
    Well I went back at it this morning. The snap ring pliers I have arent long enough to pull the snap ring off of the MC. Off to harbor freight.
    Im just going to order a complete rebuild kit from the dealer for the calipers and MC. Today I will get them 100% pulled apart and cleaned. That way after my 5 day wait I can put it all back together and ride.
    Still kinda nasty here in Portland OR anyway so, I hope to be done with all I need by mid month.
    When in doubt, knock 'em out!
    I will not argue with idiots. They will only try to drag me down to their level and beat me with experience.
    • nemesis71
      • 12
      • ohio
      Originally posted by Suckerpunch
      Do I need to pump the brake handle while doing this?
      no just repeat until you get fluid without any air bubbles
        I am about to pull my MC apart this evening. Good things to learn here!
          #34
          None of the HF snapring pliers I saw would work for it. I actually used two rat tail files and ground the ends that go into the handle down to fit the snap ring. Using two of them I was able to pry it out. Otherwise, I think MikesXS has a tool for the job.
            #35
            OK, did you try teflon tape on the bleeder screw so it doesn't suck air?
            I'll back up what Phil says; if you don't put teflon tape (or some sort of thread sealer) on the bleed screw, the Mitivac will just frustrate you. It makes all the difference...
            '78E original owner
            • newc4
              • 643
              • Vienna VA
              #36
              Snap Ring Pliers
              If you've some snap ring pliers you can push the plunger all the way in to get extra room to work. It took me a while to figure out this easy solution.
              Darrell
              Darrell
              78E
              80G project
              06FJR
              • Suckerpunch
                • Apr 2010
                • 116
                • Portland Oregon
                #37
                update
                Well I found a trick to bleeding that works for me.
                I got the brakes to pump the piston out of the caliper today (both front calipers). They were nasty! So glad I took the advice to rebuild them. They were caked with all kinds of nasty white crap that was as hard as a rock. The o-rings were all mushed in, and the grove they sat in were all bumpy with rust and hard dirt build up.
                I ordered the rebuild kit today. Tomorrow I tear down the MC
