I just read TopCats pictorial on rear wheel removal, the day AFTER I removed the wheel! Could have put some of his tips to use, but all in all it went ok. I did have a question though, my axle was a LOT harder to remove than it sounds like it should have been. It took a carefully placed punch, & a 3# sledge hammer to drive it out. There seems to be a buildup of rust alond the entire length, although it wasn't "dry", there seemed to be a light greasy film. I was thinking a fine steel wool, & thougough re-greasing before I re-install. Does that sound right?
Rear Wheel Removal
Use whatever you can to get the rust off without scratching up the axle surface too much. Fine emery cloth would be good also. I use it to polish cranks if I'm not having them ground. I also used high-temp wheel bearing grease on my axle when re-installing and put some on the teeth for the gear drive. Though other more experienced XSr's may have better advice.1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay. -
Timing is everything!
Hey Lloydo,
Sorry about that!
IF I didn't say so in the tech tip, I'll add it, but yes, I put some bearing grease on the axle shaft as well before putting it back in! Mine also had some mild rust, used emory cloth or such to remove it.
T.C.T. C. Gresham
I had the same thing with my project bike. Any of them that sit around for a while will have this issue.
I would take a rag and rub it down as smooth as it gets, clean it up with someacetone or something similar, then coat it with grease. I have a can of high speed bearing grease I use on all such items.Life is what happens while your planning everything else!
78 XS750Comment
While you have the wheel off, remove all of the crusty grease from the spider gear and regrease it also. And... you might want to remove the drive shaft to grase the splines at the final drive because the grease zerk does not do a good job.Skids (Sid Hansen)
Re-Install
I knew this would happen, too long since I took it apart, & I didn't take pics! Just wanted to double check the order the bolt goes through, from right to left, ( from behind ):
right swingarm
caliper bracket
caliper itself
collar (spacer?)
wheel
final drive
left swingarm
Correct? The clymer manual I have has what looks like a spcer between the right swingarm & the caliper bracket, in addition to the collar that goes into the disc/rotor. Topcats pictorial shows only the collar as a spacer, & does say the "special" spacer. Just wanted to be sure I didn't lose an extra spacer. BTW, I did go over the axle with some 400 sandpaper & re greased it, slid all the way through by hand!Comment
spacer
If it's a special, the spacer is already attached to the caliper torque plate.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Also maybe use a small screw driver to wedge open the gap where the pinch bolt does. Might help or not. took my brake lever off and had to do that .Just a tiny bit helped.79SF
XJ11
78EComment
Well mine must be welded in. I've loosened the pinch bolt and flogged the living shinola out of it with a five pound lump hammer and it wont budge. Any clues?
Dan.Automotive Imbecile.
Proud owner of 'The Swiftcicle'. (Swifty for short)
'78E Full Vetter Dresser.
1196 Big Bore Kit.Comment
Drive a screw driver in the wedge slot and open it up. Insert a big phillips screwdriver in the hole on the end of the axle and start rotating. Once the axle rotates reasonably it will pull out.1970? Honda Z50... gone
1974 Honda CB200... gone
2008 Honda VTX 1800F
http://www.johnsoldiron.comComment
You can also heat up the AXLE from the nut side with a propane torch, and then hit it with penetrating oil. The cooling should allow the oil to get into the axle a way's. Don't forget to heat around the brake side, but be careful! The end of the axle you pull on has plastic inside of it, and that may melt and burn if you go too heavy with the heat.
Most of the rust IS between the wheel and swingarm on the BRAKE side, so plenty of oil in that area.Ray Matteis
Thanks gang. I'm going to try vice grips and patience. I don't have a propane torch and I can't see anywhere where I might use a large phillips screwdriver.Automotive Imbecile.
oops thought I had a good pic of the set up but nope1979 XS1100SF.
"You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
