On the brake side of the axle there is a hole drilled through the axle. the hole is about 1/4" in from the end of the axle so it is possible that it is at least partially covered up by the swingarm. You can stick a punch or a screwdriver in there and use that hole to twist and pull on.
You did remove the pinch bolt on the right side of the swingarm didn't you ?
