Rear Wheel Removal
  • Lloydo
    • May 2003
    • 60
    • Glendale WI
    Rear Wheel Removal
    I just read TopCats pictorial on rear wheel removal, the day AFTER I removed the wheel! Could have put some of his tips to use, but all in all it went ok. I did have a question though, my axle was a LOT harder to remove than it sounds like it should have been. It took a carefully placed punch, & a 3# sledge hammer to drive it out. There seems to be a buildup of rust alond the entire length, although it wasn't "dry", there seemed to be a light greasy film. I was thinking a fine steel wool, & thougough re-greasing before I re-install. Does that sound right?
  • jimbyjimb
    • Feb 2010
    • 263
    • Seattle
    Use whatever you can to get the rust off without scratching up the axle surface too much. Fine emery cloth would be good also. I use it to polish cranks if I'm not having them ground. I also used high-temp wheel bearing grease on my axle when re-installing and put some on the teeth for the gear drive. Though other more experienced XSr's may have better advice.
    1990 Ninja ZX-10. It's the Silver Surfer. HI-YA!!
    2006 Yamaha XT-225. Yep, I take it on the interstate. It's Blue Butt.
    1982 Toyota 4x4. 22R Cammed, 38/38, 2" pipe, 20R head with OS valves, performance grind and other fun stuff. It's Blue RASPberry.
    1969 Ford F-250 Camper Special resto project. 390 RV cam, Demon carb, Sanderson headers, 2 and a quarter pipes with Magnaflow mufflers. It's Blue Jay.
      Timing is everything!
      Hey Lloydo,
      Sorry about that! IF I didn't say so in the tech tip, I'll add it, but yes, I put some bearing grease on the axle shaft as well before putting it back in! Mine also had some mild rust, used emory cloth or such to remove it.
        I had the same thing with my project bike. Any of them that sit around for a while will have this issue.
        I would take a rag and rub it down as smooth as it gets, clean it up with someacetone or something similar, then coat it with grease. I have a can of high speed bearing grease I use on all such items.
          While you have the wheel off, remove all of the crusty grease from the spider gear and regrease it also. And... you might want to remove the drive shaft to grase the splines at the final drive because the grease zerk does not do a good job.
          • Lloydo
            • May 2003
            • 60
            • Glendale WI
            Re-Install
            I knew this would happen, too long since I took it apart, & I didn't take pics! Just wanted to double check the order the bolt goes through, from right to left, ( from behind ):
            right swingarm
            caliper bracket
            caliper itself
            collar (spacer?)
            wheel
            final drive
            left swingarm
            Correct? The clymer manual I have has what looks like a spcer between the right swingarm & the caliper bracket, in addition to the collar that goes into the disc/rotor. Topcats pictorial shows only the collar as a spacer, & does say the "special" spacer. Just wanted to be sure I didn't lose an extra spacer. BTW, I did go over the axle with some 400 sandpaper & re greased it, slid all the way through by hand!
            • Lloydo
              • May 2003
              • 60
              • Glendale WI
              Re-Install
              Sorry, forgot......at the end is a washer & then the nut.
              • mack
                • 2411
                • Ontario, Canada
                spacer
                If it's a special, the spacer is already attached to the caliper torque plate.
                mack
                79 XS 1100 SF Special
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                https://youtu.be/wB5Jfbp6SUc
                https://youtu.be/RaI3WYHSuWA
                Frankford, Ont, Canada
                613-398-6186
                • Lloydo
                  • May 2003
                  • 60
                  • Glendale WI
                  Thanks, that's what I thought, just wanted to be sure!
                  • SFerinTEXAS
                    • Jun 2006
                    • 877
                    Also maybe use a small screw driver to wedge open the gap where the pinch bolt does. Might help or not. took my brake lever off and had to do that .Just a tiny bit helped.
                    79SF
                    XJ11
                    78E
                    • Stralya
                      • Apr 2006
                      • 791
                      • 'Blotto Grotto' Wodonga, Victoria, Australia.
                      Well mine must be welded in. I've loosened the pinch bolt and flogged the living shinola out of it with a five pound lump hammer and it wont budge. Any clues?
                      Dan.
                      Automotive Imbecile.
                      Proud owner of 'The Swiftcicle'. (Swifty for short)
                      '78E Full Vetter Dresser.
                      1196 Big Bore Kit.
                      • WSL91
                        • Feb 2012
                        • 427
                        • Quad Cities, IL
                        Drive a screw driver in the wedge slot and open it up. Insert a big phillips screwdriver in the hole on the end of the axle and start rotating. Once the axle rotates reasonably it will pull out.
                        1970? Honda Z50... gone
                        1974? Yamaha 100 Enduro... gone
                        1974 Honda CB200... gone
                        1981 Yamaha Virago 750... gone
                        1993 Honda Shadow 1100... gone
                        2008 Honda VTX 1800F
                        1982 Yamaha XJ1100J w/850 final, Raptor ACCT
                        1979 Yamaha XS1100SF "Chewey" Raptor ACCT
                        http://www.johnsoldiron.com
                          You can also heat up the AXLE from the nut side with a propane torch, and then hit it with penetrating oil. The cooling should allow the oil to get into the axle a way's. Don't forget to heat around the brake side, but be careful! The end of the axle you pull on has plastic inside of it, and that may melt and burn if you go too heavy with the heat.
                          Most of the rust IS between the wheel and swingarm on the BRAKE side, so plenty of oil in that area.
                          • Stralya
                            • Apr 2006
                            • 791
                            Thanks gang. I'm going to try vice grips and patience. I don't have a propane torch and I can't see anywhere where I might use a large phillips screwdriver.
                            1196 Big Bore Kit.
                            • Mr.Bill
                              • Aug 2009
                              • 118
                              • Clarksburg Maryland
                              oops thought I had a good pic of the set up but nope
                              1979 XS1100SF.
                              "You know what makes me sad... YOU DO, Why dont we run over to mamby pamby land and get you some self confidence you jack wagon" Will go down as one of the great quotes LOL
