Fork Seals - Here we go again
  • Briggs&Stratton
    • Mar 2014
    • 47
    • Grand Forks, ND.
    #61
    I think the '79 was a "taller" seal than the newer ones. ID X OD X Height, with the Height being about 2mm taller. a spacer of some kind will take care of any problems.
    I think you're right about them being taller. I got my George seals in the mail, they're not tall enough. Getting discouraged here. I'm going to dive in and pop the 79 seal out. Maybe something will make sense.
    79 SF
    IG "9mmHeater"
    • Briggs&Stratton
      • Mar 2014
      • 47
      • Grand Forks, ND.
      #62
      Crisis averted. I think. Apparently there is another rubber piece underneath the seal of a 79 special, and that takes up the extra space. I know I'm not gonna risk taking it out and damaging it, I'll clean out the inner area with it assembled. You can see it in this pic. I'd like to take it out just so there would be a clear pic for future reference on this site, but its too risky.
      The new seal appears to be the same as what came out:
      79 SF
      IG "9mmHeater"
      • Briggs&Stratton
        • Mar 2014
        • 47
        • Grand Forks, ND.
        #63
        Got it.
        I'm going to dive into the other leg.
        BTW, I used Crazy Steve's excellent rebuild method/pictorial. Thanks Steve! Here's the link http://www.xs11.com/forum/showthread...ght=fork+seals
        79 SF
        IG "9mmHeater"
        • Axel
          • May 2007
          • 869
          • Renfrew,Ontario
          #64
          Nice
          Good pics and polished tube !
          XJ1100K
          Avon rubber
          MikesXS black coils
          Iridium plugs w/ 1k caps
          MikesXS front master
          Loud Horns (Stebel/Fiamm)
          Progressive fork springs
          CIBIE headlight reflector
          YICS Eliminator
            Well, at least the dust seal will cover the gouge marks from the 'ham-fisted' old seal removal.
            • Briggs&Stratton
              • Mar 2014
              • 47
              • Grand Forks, ND.
              #66
              Please post the pics of your shinier lowers. That way you can prove to everyone you're the better craftsman and maintainer.
              79 SF
              IG "9mmHeater"
                • 5073
                #67
                Damn Brent!
                  • 5073
                  #68
                  Damn Brant!
                  • Axel
                    • May 2007
                    • 869
                    • Renfrew,Ontario
                    #69
                    reminder
                    So just to remind anyone (myself) , the part number above (51490 GBF 831) is Honda and for one seal only . Included is the honda CR80 dust cover .
                    I just ordered one thinking I was getting two seals bit I was mistaken .
                    This is for an XJ1100 .
                    XJ1100K
                    Avon rubber
                    MikesXS black coils
                    YICS Eliminator
                      • 8893
                      Briggs, any idea how tall that lower spacer is? That looks like it was put there in place of the flimsy crinkle cut spacer that was there from the factory. There might be numbers on it too. I have made them out of PVC pipe too.
                      • Briggs&Stratton
                        • Mar 2014
                        • 47
                        • Grand Forks, ND.
                        #71
                        I'd say it was right around 1/8 inch tall. As you see in the pic, there is still the thin metal spacer underneath.
                        The rubber part you see didn't move or fit loose, but it didn't appear that any part of the circumference actually touched the wall of the lower, so I suspect it was fastened to that thin metal spacer below it. Also, since the rubber part didn't touch the edge of the bore, I suspect that the bottom outer edge of the seal partially slid over this rubber spacer.
                        If that doesn't make sense, I can try to explain differently.
                        79 SF
                        IG "9mmHeater"
                          Can't beat that for polished!
                          No offense intended, but your 'before' and 'after' pics of seal removal were a 'given'.......couldn't resist.
