Fork Seals - Here we go again
  • Axel
    • May 2007
    • 869
    • Renfrew,Ontario
    and then ...
    Last year I got by with more clean-up on the All-Balls seal side . The Honda seal was perfect . This year I had to install the second Honda seal as the All-Balls gave out completely after a few runs .
    All went well ( I think) but my brake pads are pretty useless from fork oil .
    I guess that's next .
    XJ1100K
    Avon rubber
    MikesXS black coils
    Iridium plugs w/ 1k caps
    MikesXS front master
    Loud Horns (Stebel/Fiamm)
    Progressive fork springs
    CIBIE headlight reflector
    YICS Eliminator
      I wonder if you could "de-brake fluid" them with a short soak and brushing in acetone? I assume you already hit them with the Brake Kleen spray.
        Wasn't a perfect result, but used to take brake shoes that were seriously contaminated with oil from leaky seals on large trucks, equip, etc. and get them hot steam cleaning, then tossing them in 'floor dry' material(cheap cat litter likely the same), which would draw majority of contaminents out. It was a 'hit and miss' thing, but sometimes worth a try if they weren't extremely imbedded with oil and such.
        Had the same thing on front of the Bentley with it sitting in garage, front facing opened door catching afternoon sun and heat on left fork. Having a few lbs. of air in them combined with the heat pushed a weep of fork oil out and down the fork leg onto the caliper assembly to the pads on left side.
        Let the 9lbs. air out of each fork, pulled up the dust seal, cleaned everything spraying BraKleen and ran the Motion-Pro Seal Mate down past and around seal, to remove any possible trapped foreign matter between seal and 'piston'. Rocking bike for and aft on centerstand, working the forks with front brake on afterwards for any re-seating of seal lips, and then riding 100mi. on highways with dips enough to utilize suspension travel for a test. So far, nice and dry, so least successful so far.
        30+ yrs. ago, that was an old trick on our moto-x bikes using a piece of 35mm film......way, way before MotionPro picked the idea up commercially, and actually designed a 'hook' look to the end of it trapping anything as it is rotated around and pulled out.
        For any interested, most any of the bike shops/dealers carries them.
        Use it over and over again for under $5 IIRC.
          Hi Skids,
          Alot of folks, based on location cannot get the 'real' BraKleen like we still can.
          Most have to settle for the 'Green can'........which is bout worthless, but better than none at all.
          • rdmcguy
            • Jul 2013
            • 515
            • Denver, Colo.
            #35
            brake pad cleaning
            An old trick that works to varying degrees
            Take your propane torch with map gas and heat the metal side of the pads,
            You can often watch the oil weeping out,
            Another old trick is to put a bit of alcohol in the fork leg to "swell"the seal a bit.
            (I have used a syringe)
            Both of these are somewhat of a band aid but work in a pinch.
            • Axel
              • May 2007
              • 869
              • Renfrew,Ontario
              #36
              rotate pads ?
              Might be a silly question but as one pad in each caliper is thicker than the other , can you switch them around to get more life fom them ?
              XJ1100K
              Avon rubber
              MikesXS black coils
              YICS Eliminator
              • wingnut
                • 695
                • NC
                #37
                Have ya tried heating the lower tubes in the hottest water you can get out of the tap before you install the seals? Works for me every time.
                wingnut
                81 SH (Daily Ride)
                81 XS 400
                Thomas Jefferson
                • Axel
                  • May 2007
                  • 869
                  • Renfrew,Ontario
                  #38
                  hmm
                  Well. I installed the second Honda fork seal and seem to have messed it up . Got me through the season but weeps . I need to have more patience and the right place to work . My friends bike shop was the perfect combo. The arbor press didnt hurt either.
                  XJ1100K
                  Avon rubber
                  MikesXS black coils
                  YICS Eliminator
                  • Axel
                    • May 2007
                    • 869
                    • Renfrew,Ontario
                    #39
                    Brake pads
                    I bit the bullet and got Kevlar all around from Cali . The shipping cost more than the pads but I got 3 sets for the price of one here including the shipping cost .
                    XJ1100K
                    Avon rubber
                    MikesXS black coils
                    YICS Eliminator
                    • Arthur_of_Hex
                      • Oct 2014
                      • 89
                      • Bangor, ME.
                      #40
                      Here at the shop we have a collection of seal drivers...seperate, reconnect around the fork, drive in the goodies. The best part is smashing the meat of your hand between the tool and the fork...
                      Matt
                      81H Rebirth/Custom Build
                      1st Gen RX7; Audi quattro; Wrangler JK
                      PanikSwitch Cycles - Brewer ME
                      http://s48.photobucket.com/user/Arth...201100%20Build
                      • Briggs&Stratton
                        • Mar 2014
                        • 47
                        • Grand Forks, ND.
                        #41
                        Originally posted by Axel
                        Allballs seal still working . I replaced the other aftermarket seal with an OEM Honda fork seal . There are quite a few Hondas with the same seal . A little more expensive ($30 each) and it comes with a dust cap specific to whatever model you order it for ( I used CR80r 1996-2002) so you dont use that of course . The Honda seal is a triple lip a lot like the Allballs but it installs beautifully . This time I got to use the bike shop's tools and bay and took my time and it all went well . My mech friend helped me with the details . I'm happy to say it is working well !!!
                        Part number I used is 51490-GBF-831
                        Has anyone else used this Honda seal? And in a special? I ordered a set and the height appears to be too short, compared to the factory seal. By short, I mean it would fit well under the retaining clip.
                        I'll have to re-learn how to post pics.
                        79 SF
                        IG "9mmHeater"
                        • Briggs&Stratton
                          • Mar 2014
                          • 47
                          • Grand Forks, ND.
                          #42
                          This is the factory 79 special seal:
                          79 SF
                          IG "9mmHeater"
                          • Axel
                            • May 2007
                            • 869
                            • Renfrew,Ontario
                            #43
                            XJ only
                            This seal is for an XJ and possibly a MNS only . Sorry for any mixup you had . Nice pics BTW .
                            XJ1100K
                            Avon rubber
                            MikesXS black coils
                            YICS Eliminator
                            • Briggs&Stratton
                              • Mar 2014
                              • 47
                              • Grand Forks, ND.
                              #44
                              Ahhh alright. Thanks for getting back to me!
                              79 SF
                              IG "9mmHeater"
                                For OEM seals the XS1100SF seals are peculiar to just that bike. For some reason the XS1100SF parts fiche has been removed from the places I look for parts. SF has been removed from the Yamaha site as well.
