Fork Seals - Here we go again
  • Briggs&Stratton
    • Mar 2014
    • 47
    • Grand Forks, ND.
    #46
    Does anyone have a recommendation where to get SF seals? Allballs doesn't have any listed that I can see.
    The dealer 20 miles from me thought they could order them but then decided they couldn't. The dealer 60 miles from me literally laughed when I said 1979. He claimed the computer doesn't go back that far and told me to "look online."
    Any rec's for a company that sells a quality seal and ships quickly?
    79 SF
    IG "9mmHeater"
      • 1987
      Georgefix
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        #48
        If the fork seals for the SF are different than any other then George must be confused as to what fits what ?
        Notice he lists the Honda as one of the applications. ??
        For OEM seals the XS1100SF seals are peculiar to just that bike. For some reason the XS1100SF parts fiche has been removed from the places I look for parts. SF has been removed from the Yamaha site as well.
        76 XS650 C ROADSTER
        80 XS650 G Special II
        https://ibb.co/album/icbGgF
        80 XS 1100 SG
        81 XS 1100LH/SH DARKHORSE
        https://tinyurl.com/k6nzvtw
        AKA; Don'e, UD, Unca Don'e
        • Briggs&Stratton
          • Mar 2014
          • 47
          • Grand Forks, ND.
          #49
          I see that. Can anyone confirm before I order?
          79 SF
          IG "9mmHeater"
            • 8062
            All of the aftermarket seals are specified for all of the Specials. Only the SF had a different OEM part number. I don't have an SF, so I never made a hard copy of the SF parts book. I also wonder why the SF manuals have been taken down.
            Surely, others have used aftermarket seals in the SF. Partzilla lists a bunch of them with the '79 on the fitment list. I had to put SG in the search as the SF no longer exists. They're offered in various sizes for the 37 mm tube.
            Looking at the list, I wouldn't know what to buy.
            • Axel
              • May 2007
              • 869
              • Renfrew,Ontario
              #51
              check but this is what I have
              Oil Seal - (2H7-23145-00) 41Y-23145-00-00 $11.89 .
              http://www.yamahasportsplaza.com/oem...240/front-fork
              XJ1100K
              Avon rubber
              MikesXS black coils
              Iridium plugs w/ 1k caps
              MikesXS front master
              Loud Horns (Stebel/Fiamm)
              Progressive fork springs
              CIBIE headlight reflector
              YICS Eliminator
                • 8062
                That's an F. We need seals for SF.
                • Briggs&Stratton
                  • Mar 2014
                  • 47
                  • Grand Forks, ND.
                  #53
                  Well, I rolled the dice and ordered the George seals. It says 79-81 specials.
                  79 SF
                  IG "9mmHeater"
                    • 8894
                    All the Specials use the same fork seal (37X48X10.5) except the 81 MNS which uses the same fork seal as the XJ11 does.
                      • 8062
                      Phil,
                      You may be just the guy to have the answer. Why does the SF seal OEM part number differ from the other Specials?
                        • 8894
                        I don't know the answer to that Marty, I have always wondered the same thing.
                          • 8894
                          Only a guess, maybe the 79 Special seal had a double lip and the 80+ was a triple.
                          • Briggs&Stratton
                            • Mar 2014
                            • 47
                            • Grand Forks, ND.
                            #58
                            This is the seal in my 79, but who knows if it has been replaced in the past. Looks triple though?
                            79 SF
                            IG "9mmHeater"
                              • 7819
                              I think the '79 was a "taller" seal than the newer ones. ID X OD X Height, with the Height being about 2mm taller. a spacer of some kind will take care of any problems.
                                • 2140
                                I have been happy with these for $9.74/pair (now $9.25) including shipping:
                                http://www.ebay.com/itm/Fork-Oil-Sea...item53f42de7fd
                                I bought from the same source for both of XS750 with good results.
