Wider front tire?
  • #16
    I'm "on the list" for some FJ take off forks and trees, once I get those I'll be looking into this more, possibly running a 17 rear rim on the front. I could use the FJ rim, but it won't match...
    1979 xs1100 Special -
    My Bike:
    [link is broken]
    • #17
      Originally posted by bwilding_2000 View Post
      Hey, since we are talking about front rims, will a standard and a special front rim swap? Are any special parts needed?
      Short answer....Yes and no. Just the rears are different.
      As to trying to 'adapt' a rear to the front... sheesh, the machine work! If I was really determined to do this, I'd find a first-class tig welder and weld the front center into the rear rim...
      '78E original owner
      • #18
        there is a set on ebay, forks and tripple trees for a buy it now of $50
        Harry
        '79 Standard
        '82 XJ1100
        '84 FJ1100
        Acta Non Verba
        • #19
          Hey, since we are talking about front rims, will a standard and a special front rim swap ? are any special prts needed?
          Hi bwilding,
          Yamaparts swap like LEGO. All XS650/750/850/1100s have the same 7-spoke cast front wheel. The 750/850 wheels have smaller brake disks but 1100 or 650 front disks bolt straight on. Even the XS650 front wire wheels will work if you change their 2-piece disks.
          • #20
            Wider front tire
            I went slightly wider with my front tire on my 1979 xs1100"f". I am running Metzlers front and rear. I bought a 110-90, 19" for the front. I had to loosen the brake calipers to slip the wheel on. What I found is alot less "groove tracking" effect on the highway. With the original size I found that the bike wanted to stay in various grooves and creases. I run both front and rear at 40 psi. When riding in the rain, I decrease the rear to 35psi.
            Some days you're the pigeon..and some days you're the statue/
            1979 XS1100f
            Saddle bags, small wind screen and non-original rear shocks. Otherwise..completely stock.
