I'm "on the list" for some FJ take off forks and trees, once I get those I'll be looking into this more, possibly running a 17 rear rim on the front. I could use the FJ rim, but it won't match...
Wider front tire?
1979 xs1100 Special -
My Bike:Originally posted by fredintoonGoes like a train, corners like a cow, shifts like a Russian tractor, drinks like a fish, you are gonna love it.
[link is broken] -
Short answer....Yes and no. Just the rears are different.
As to trying to 'adapt' a rear to the front... sheesh, the machine work! If I was really determined to do this, I'd find a first-class tig welder and weld the front center into the rear rim...
'78E original ownerFast, Cheap, Reliable... Pick any two
there is a set on ebay, forks and tripple trees for a buy it now of $50Harry
'79 Standard
'82 XJ1100
'84 FJ1100
Acta Non VerbaComment
Hi bwilding,
Yamaparts swap like LEGO. All XS650/750/850/1100s have the same 7-spoke cast front wheel. The 750/850 wheels have smaller brake disks but 1100 or 650 front disks bolt straight on. Even the XS650 front wire wheels will work if you change their 2-piece disks.Fred Hill, S'toon
"The Flying Pumpkin"Comment
Wider front tire
I went slightly wider with my front tire on my 1979 xs1100"f". I am running Metzlers front and rear. I bought a 110-90, 19" for the front. I had to loosen the brake calipers to slip the wheel on. What I found is alot less "groove tracking" effect on the highway. With the original size I found that the bike wanted to stay in various grooves and creases. I run both front and rear at 40 psi. When riding in the rain, I decrease the rear to 35psi.Some days you're the pigeon..and some days you're the statue/
1979 XS1100f
Saddle bags, small wind screen and non-original rear shocks. Otherwise..completely stock.Comment
