I'm not going to get in a pissing contest over this but I use diodes in my rectifiers that are better than 2x the load capacity of the ones in the stock reg/rec unit.
you can bitch about the wiring all you want but it's up to the load it was designed for and all high draw accessories should wired in by way off a relay off the solenoid.
If you're worried about the power draw off the rectifier melting the wires in the harness. You could run 2 wires from the rectifier to shuttle power on larger wires...
I think your connection losses are over stated. I've only seen a heat loss problem on corroded connections and that's another good reason to pack connections in dielectric grease.
Geezer
Geezer
The oldest telegraph splice - the original mainstay of telegraph wire connections is known, appropriately enough, as the Western Union joint. 'Cold' (that is; not soldered - just twisted together), it is about 65 percent efficient and retains about 55 percent of the strength of the wire. Soldered, it becomes over 95 percent efficient.
