Carb sync opinions
  • mack
    • 2411
    • Ontario, Canada
    Carb sync opinions
    I'm looking into Carb sync tools. 1. Morgan "Carbtune pro", 2. Motion pro "Synch pro" and 79xs11F sent me a thread on the KZGS carb sync "guage balancer". I'd like to hear from anyone who has used these. Ease of use, reguired adapters, accuracy and since my eye's aren't what they used to be, easy to read? Thanx guys
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
  • tinman905
    • Aug 2007
    • 946
    • Orangeville,Ontario ,Canada
    I use the Morgan Carb Pro and love it . Next to no maintenance accurate easy to see and it's not a piece of junk that will break easily or has anything that will leak. Everything is neatly tucked away in a nice soft case until you need to use it again.
    BDF Special
    • tarzan
      • 1700
      • Chandler,Az.
      I have a Morgan.It is great.I have used sticks and gauges, but I like the Carbtune best.
      Sticks work great, but the mercury makes them a PITA to store.
      And you can suck mercury into the carbs if you blip the throttle.
      Gauges are ok, but cumbersome in my opinion.
      The Carbtune works great and easy to store.
      80 SG XS1100
      14 Victory Cross Country
        • 3193
        The Morgan Carbtune is number one in my books. Comes with everything you need. I also bought the carrying case which is also a nice feature. It took ten days shipping time from the UK to my place in Alberta Canada which is really quick. Very easy to use instructions etc. Reading them is a breeze and they have no liquid elements so they cant develop bubbles or get sucked into the carbs. They will also come apart if you need to clean or rebuild them. They are a quality made item and I am very happy to be using them and DO highly recommend them.
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          I have and love my Morgan Carbtune.
          1980 XS 1100SG
          Dyna 3 Ohm Hi Output Coils
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
          • slow mo
            • 858
            • ontario canada
            my vote is the Morgan pro right James! ride safe ,,slow mo?
            The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
            moemcnally@hotmail.com
            i AM THE KING OF NOTHING
            the people here are great , doesn't matter about the bike really/hamjam ////
            • TDodge7
              • May 2009
              • 246
              I love my morgan carbtune , pay the extra and get the soft bag with it as well , it's well worth it .
              • dbeardslee
                • 4385
                • Maineville, OH
                I started with mercury sticks. It was great 'till a burp from the carbs sent fuel back into the mercury which effectively killed it. So I setup a 4-gauge synchronizer, and it worked great and was very accurate after calibration. It was however a little big to carry around, and I wound up buying a Carbtune Pro. Nice ergonomics, very accurate, and very compact. They also bundle it with a nylon case and a colortune plug. Unless you're good at setting your carb mixtures by ear or have an accurate tachometer to do it with, IMHO you need both tools (carbtune and colortune) to accurately adjust your carbs. My advice is to go with this - 14mm plug size.
                • res1uqtp
                  • May 2009
                  • 84
                  • East Central IL
                  Carbtune / Colortune Invaluable Combo
                  I swear by my morgan Carbtune and Colortune combo. It was hard to part with the money when I bought them and after the first time I used them together I wondered why I ever did it the hard way .....
                  My Stable:
                  2006 Triumph Bonneville Black
                  1979 Yamaha XS11 Special (2 of them)
                  1982 Yamaha XS400 Heritage Special
                  1981 Suzuki GS550 E
                  1976 Honda CB550F Supersport
                  • XSrunner
                    • Feb 2008
                    • 97
                    • Batemans Bay AUSTRALIA
                    I also would recomend the morgan carbtune pro vey easy to read and set up ans with the dollar and pound exchange rate its good value to get now
                    JOHN'O
                    Xs1100E 1978
                    American Import Cruiser
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      Awe yes, the nay-sayer as usual. If you love waisting money, go for the Morgan. However, you can achieve the same or better results with a home built, 4-way linked, vinyl tubing manometer for less than $10.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                      • DenyP
                        • 599
                        • Staples, Minnesota 56479
                        You have to admit it is fun to use a nice piece of equipment. The carbtune is great, glad I spent the money.
                        Deny
                        • CA
                          • Feb 2009
                          • 267
                          • Nashville, TN
                          What they said
                          I too was in the same boat and bought the Morgan Carbtune a month ago, Used it for the first time yesterday, and loved it. It was plug and play, and I wandered why I wouldn't synch the carbs once a month with this thing...it is so easy.
                          I once tried to take the cheap way and build my own synch machine...it worked that time, barely and very painfully, but now its $15 and a pile of random tubes and a broken 4 way plastic valve....so do yourself a favor.
                          1979 XS1100SF (4-1 Kerker, XS Pods, 145 mains, 45 pilots, drag bars, blacked out)
                            It would be nice to have, but I'm too cheap azz to buy the Morgan Carbtune. I use a cheapo JCW 4 guage setup that works fine. The downside is I have to syncronize the guages every time before using with a mity vac.
                            • tinman905
                              • Aug 2007
                              • 946
                              Speaking of cheap azz's has Phil made over to meet you yet Phil.
                              BDF Special
