Man, this is a dumb one...
  • 1sttimeXSowner
    • Aug 2009
    • 33
    Hey, I know this is a dumb-a$# question but I gotta ask it cause I can't get anything else done to the bike til I do...how the heck do you get the freakin seat off???????? When I use the key to unlock the sucker, it does, but then I can't get the thing to come off. Yep, I'm a newbie so pretty dumb and inexperienced but is there a trick from that point to get it off? Blast away you guys with all the smart remarks but someone seriously tell me my answer please!!! Thanks!
    1982 XJ1100J; 2006 Suzuki Boulevard C50
    Athens GA
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." -Benjamin Franklin
  • joceiphus
    Xsive
    • Oct 2009
    • 285
    • Tulsa
    Mine had a bolt on each side, and you'd just loosen and pull back.
    Joe
    78XS1100
    • fabricgator
      • Feb 2010
      • 67
      • Treasure Coast, Florida
      Hello,
      Mine has nuts on either underside of seat that have to just be loosened and then slid forward or is it back. Then you lift up slightly and slide back from under the tank.
      Hope this is your answer...
      Kurt
      I have a parking problem everywhere I go....
      2001 Mitsubishi Montero
      1987 944 n/a
      1979 Titan
      1979 Yamaha XS 1100 SF
      1984 Suzuki SP 250
      1987 Santana 23
      1944 Aeronca L-3B Grasshopper
      If it fly's, float's or fornicates..... your better off having a lease!
      • randy
        • Dec 2003
        • 4521
        Actually the answer is even more dumb-ass than the question. The seat is bolted down I kid you not. The lock you saw is a helmet lock. Two 14mm nuts under the seat by the frame rails.
        • randy
          • Dec 2003
          • 4521
          Get yourself a service manual.
          • Bigge_al
            • Jul 2008
            • 98
            • Pleasant Garden, North Carolina
            seat removed
            Not to go against everyone but my seat lock has a latch/lever that I have to push down on both sides. On the lock side the lock turns one way to release the helmet latch and the other releases the seat but I still have to push down on the lever.
            Eric (South of Greensboro, NC)
            82 XJ1100 "Echos" Mostly Stock
            Matthew 4:19 "Follow me and I will make you fishers of men"
            • Yahman
              • Mar 2008
              • 779
              • Salem, OR
              It looks like you are asking about an XJ, not an XS. The key lock only releases the one side. These is a little lever on each side of the seat lock mechanism that you flip. Then lift the back of the seat and slide it back toward the rear of the bike. At this point it should just lift right off.
              Larry
              82 XJ1100
              80 XS1100G (Project bike)
              64 Yamaha YA-6
              77 Suzuki TS-185
              • randy
                • Dec 2003
                • 4521
                Damned XJ's -
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  As suggested, you should get a manual. You can download one for free from the link in my signature. You'll find there are a few things (like this one) that are unique about the XJ when comared to the XS's.
                  You should also put your model in your signature so we know what bike you're asking about.
                  • 1sttimeXSowner
                    • Aug 2009
                    • 33
                    Larry
                    Thanks man--absolutely right, i do have the XJ1100 and your response worked for me. I also downloaded the service manual so...today's been a good day. Could make it a better day now if someone has some tips on cold-weather starting after the bike's been sittin for a week or two!
                    Athens GA
                      • 8802
                      Clean the enriching (choke) circuit passages in your float bowls. JAT
                      • XJOK2PLAY
                        • 2099
                        • Skiatook, Ok.
                        1sttimeXSowner,
                        You might also update your signature, and put the bike type, year, all that good stuff there, that way we can tell what ya got and help ya better.
                        Case in point: XS seats bolt down... XJ's have 2 levers on each side...
                        If they give ya too hard of a time around here... you can always PM me... I've got one too.
                        Randy: Don't be cussin the XJ's... just cause Yamaha finally got smart & fixed a bunch of the XS's shortcommings in '82! LOL
                        2011 Kaw Concours 14 ABS
                        • Bigge_al
                          • Jul 2008
                          • 98
                          Perfection
                          Like XJOK2PLAY said they got it right in 82 they are just sad they don't have perfection.
                          • TomRodgers
                            • Jun 2008
                            • 492
                            • La Porte Indiana
                            Dude...
                            Update the signature and location....
                            For at least 75% of us out there, there is someone close by also!!! Cold starting....
                            welllllll you could always shoot some dragon juice (starting fluid) in the air filters...not the best way, but it does work...also shoot some down the cylinder if your having trouble, but best bet is to figure out WHY its starting hard cold!!!! weak spark, bad fuel. bike engines are the same as the rest. Suck, squeeze, bang, blow. any one of them can make the bike run bad.....
                            4:1 Jardine w/ headerwrap
                            Windjammer(wiring issues)
                            New paint/brakes to come!!
                            '80G FrankenBike (parts bike)
                            '80G to fix "BlackSunshine"
                            Stock Pilots/125 mains
                            Pod filters; 4:1 Kerker??
                            SS Brake lines w/ new M/C's
                            LED Brake Lite
                            Needs paint....
                            • TomRodgers
                              • Jun 2008
                              • 492
                              • La Porte Indiana
                              WHATEVER!!!!! hahahahaha
                              LED Brake Lite
                              Needs paint....
