Man, this is a dumb one...
  • mro
    • 4276
    • Hayward, California
    Hi 1st time,
    hard starting? are you twisting the throttle while it's cranking?
    If so that's at least part of the problem. Closed throttle increases vacuum which helps to draw fuel threw the enricher circuit to start.
    So pull out choke (enricher circuit) and crank. Some not in tune like a little throat action right after they fire, others in tune fire right up and RPM should go to around 12/1500 and as it warms up increases.
    Good luck, welcome to Chanel 11
    mro
    • mro
      • 4276
      Don't be cussin the XJ's... just cause Yamaha finally got smart & fixed a bunch of the XS's shortcommings in '82!
      And all this time I’ve thought that the biggest difference between an XS and XJ was that XJ’s came with a factory installed bad case of the ickieys (YICKS)
      mro
      • XJOK2PLAY
        • 2099
        • Skiatook, Ok.
        Yeah, Yeah....
        One bright feature that the XJ has that the XS don't...kick stand down warning light!!! That right there's worth it's weight in... aluminum...
        'Specially for us 'senior moment type' fellas... LOL
        Ohhhh, and we mustn't forget about the wonderful battery warning light, either! The most 'useful' item ever created for a motorcycle...
        hehehehe... I figured I'd get a few backs raised with that little comment... just figured it'd be Randy first, though...
        2011 Kaw Concours 14 ABS
          Nah. They fixed the rototiller handlbars, and made them easier to adjust. They also made the linked braking system standard. Yamaha improved the shocks on the XJ too. They increased the output of the alternator, and put more sensors on the bike to tell you when things went wrong. Of course, they also added that stupid sidestand lockout feature... I guess some people needed that one though.
          • red bandit
            • 957
            • central michigan
            Want to race!!
            79 SF parts bike.
              Nah. They also made the linked braking system standard. ....... and put more sensors on the bike to tell you when things went wrong.
              And here I thought you were listing the things they improved!
              • Yahman
                • Mar 2008
                • 779
                • Salem, OR
                mro
                I fixed that annoying little problem with the YICS Eliminator.
                Larry
                82 XJ1100
                80 XS1100G (Project bike)
                64 Yamaha YA-6
                77 Suzuki TS-185
