Splitting the f*%$#@ng cases
  • MrOzz
    • Aug 2008
    • 782
    • Massachusetts
    #46
    WOW Randy that is one nice looking XS motor.
    Since you did such a great job I am willing to drop off mine . I want my carbs blue though LOL.
    1980 XS 1100SG
    Dyna 3 Ohm Hi Output Coils
    Pod Filters
    DynoJet Kit
    T.C.'s Fuse Block
    V-Max Auto CCT
      #47
      I am in awe! Pristine! You had better be careful not to mar it putting it back into the frame!!!!!
        • 8962
        Engine looks good dude! Sexxy carbs.
        • cywelchjr
          XS-XJ Super Guru(Deceased)
          • 4450
          • Sacramento, CA
          #49
          Originally posted by randy
          The brass washers and stainless head nuts are from Mike's XS, the carbs were painted a couple of years ago with Duplicolor METALCAST. The carb painting is a project in itself cause they have to come completley apart.
          The engine is done with Rustoleum 2000degree Flat Aluminum #248904.
          Thanks for the compliments.
          Holy carp! Where's your CCA? Tell me you don't have everything buttoned up and no CCA on there and cams in place?
            #50
            That's reeeal purty....
            Nice job!
            '78E original owner
            • randy
              • Dec 2003
              • 4521
              #51
              Chiil, Cy. That's a Venturer tensioner on there, haven't put the spring and bolt on it yet.
              • cywelchjr
                • 4450
                • Sacramento, CA
                #52
                Sorry, I know your not the type to do that, and I didn't recognize the CCA there. I will say the engine looks really really good.
                • randy
                  • Dec 2003
                  • 4521
                  #53
                  Motor's going in today
                  Hurry up, I can't hold it too long...
                    Look! His face is turning the same color as the straps! lol.
                    That's a good idea, Randy. With the motors, it isn't so much the weight as it is handholds to pick it up. I usually just grab them by the middle drive shaft and the cooling fins on the head.. but when the middle drive is off, it leaves me looking for a place to grab it by. I'll have to remember that strap method. My luck though.. my straps will look OK.. but I will find out just about the time I get it lifted up... that THAT is the strap my kid left out in the sun in the back of his truck...
                    I'm thinking that from waist level... a motor dropping on a foot WOULD leave a mark. lol.
                    • randy
                      • Dec 2003
                      • 4521
                      #55
                      The straps made it a piece of cake ( a helluva cake).You can't see the one in the front, but likewise, I ran it through the mounts. If anything, it made the lift even, which helps alot! And I doubled them up for security.
                      The motor in in the frame...Beer Break! LOL!
                      • mro
                        • 4276
                        • Hayward, California
                        #56
                        Hey Randy,
                        would you and Tod please stop by and help me put the G's engine on the stand?
                        mro
                        BTW Randy, are you done with the parts I loaned you?
                        • randy
                          • Dec 2003
                          • 4521
                          #57
                          Glad to, but Tod would have a shorter walk
                          Loaned
                          • mrutah12
                            • 105
                            • back in utah
                            #58
                            splitting the f*%$#@ng cases
                            Wow randy nice job except i coulnd'nt see the first couple of pic's it just shows the photobucket image and it said it had moved or deleted was curious to see what your carbs looked like
                            4/78 xs1100 standard
                            Pacifico fairing 4 into one exhaust
                            new name :black Knight
                            I am but a student in this world of xsive masters
                            • mro
                              • 4276
                              #59
                              Valve and oil breather cover LOOKIN GOOD ...
                              if you did the filter cover and oil pan
                              you should post a pic or two for Tod
                              mro
                              • mro
                                • 4276
                                #60
                                That's OK, I just figured out how to make an engine hoist in the garage
                                so I won't have to lift it by myself
                                mro
