Phil's (not quite) Excellent Venturer
Okay, here we go:
The Good
This bike is a very rare bird. I certainly have not seen one before. It is a 1981 XS1100H standard model with the factory Venturer package, Canadian edition. It is relatively complete and original. Certainly a bike worth saving. Plastic is in good condition.
Electrical not too bad, cleaned up all the connections. Electronics yet untested.
Carbs removed, triple cleaned and adjusted. Two floats had holes in them from rubbing on incorrect float bowls. We still need two bowls.
Head had two bent exhaust valves due to improper shims. Proper shims donated by Tinman905 and exhaust valves donated by Blue Giant. Thx Guys. Used but serviceable valve springs donated by BDF. New valve seals installed
We replaced the timing chain as it had no adjustment room left. Stripped spark plug hole repair donated by Prong Built.
The Bad
Oil pan drain bolt female threads broken off. Pan had lots of sparkley bits inside, likely from trans. Oil pan donation BDF.
Clutches and transmission unchecked(my guess is both will need work)
Steering head bearings and races need changing Every other bearing on the bike needs to be checked, cleaned and repacked.
Fork seals need changing.
Rotors need to be cleaned up and checked as do pads, calipers and masters and fluid changed.
Middle drive and final drive oil change.
Needs Tires, mirrors, battery, fuel, oil and air filters, and mufflers
Exhaust pipes were welded with extensions, used stock pipes donated by BDF
The Ugly
This bike will require some serious cleaning and polishing time. I'm sure if it was detailed out it would look spectacular. The rider will probably need considerably more work to be merely presentable, But that's not my department.
The goal is for Phil to bring it to XS East and XS North.
If anyone would like to donate or give Phil a most excellent price on any of the stuff he needs, It would be greatly appreciated. There's a very tight budget on this one. I'm sure he'd let you take it for a ride when it's done.
I think we all would like to see a bike this rare saved, And it's time Phil started wearing long pants and riding a big boy bike. A full face helmet and non colour clashing riding gear would help the ugly part a lot too.
Thx Rick
Looks like Blue giant has some mirrors for the project and major props go out to our southern friend Madmax-im (BNE) who has generously donated new tires.
My thanks to all, RickI May Be Crazy, But I Have A Good Time.
Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily riderComment
We are still on track for a weekend start up. Phil's getting some O rings for the carbs. The valves donated by Blue giant lapped right in and are installed along with shims from Tinman. (I'll take you up on your offer of assistance soon).
and all my sponsors ofcourse. You guys are just great.
Thanks
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
Hi Tinman905,
No I keep forgetting to take the camera. So the posted pictures will have to be the before.
Thank You for the Valve Shims. Delivery is certainly above and beyond everything. How did you get on with the Hell Hound ?
I look forward to actually meeting you some day
PhilThe Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
moemcnally@hotmail.com
i AM THE KING OF NOTHING
the people here are great , doesn't matter about the bike really/hamjam ////Comment
Current pics of Phil's bike
This pic shows the cleaned oil pan and filter housing reinstalled.
Seeing as I took this apart, Phil should have to put it back together ...right?I May Be Crazy, But I Have A Good Time.
Hi Rick,
As you know I only come for the ABUSEEverything you touch turns to Polished Aluminum
See my email for serious question.
It did not look that rusty in my memory picture you must have a good camera
Ya gotta get old...ya don't gotta grow up.
Not polished but definitely cleaned up. Problems are easier to spot and repair if you can see them. May as well clean it when you have it off. Plus there is the esthetic value.
As for the rust, it's just some spray on rust that I bought from the joke shop.
Memory is the second thing to go..., I can't remember what the first thing was...
As for the good natured abuse, I'm like any kid. As long as I'm making noise everthing is okay. If things suddenly get quiet, it's time to go check on them.I May Be Crazy, But I Have A Good Time.
Dog without the sound
By the way guys, I posted a picture of the Hell Hound in the pet photos post.
Slow mo and Tinman, you can see what was making all the noise.
Maxim Phil you can see what she looks like without barred teeth, the dog has been asking for you.
The fairing that was in the picture of phil's is just like mine. I was beginning to think that I had the only one with a squared headlight. I hope the rest of the project goes ok and the bike turns out to be a good runner for Phil. The XS with the fairing, bags, and stuff is awesome as long distance bike. One of the first mods will have to be a 750 or 850 final drive on a bike like that.1980 XS1100 Standard "Touring"
Fairing, Trunk, and Bags
850 FD
Fork Brace
Progressive Front Springs
Engine Guards w/Foot Pegs
Oil Cooler
Throttle Lock
Uni Air Filter in Airbox
2009 Suzuki Bandit 1250S ABSComment
Time and money
As for the final drive mod, that will be up to Phil to decide. Up to this point we have been committed to keeping the bike dead nuts stock as possible because it is a rare bike. Thx RickI May Be Crazy, But I Have A Good Time.
Being an 81, if you get a FD off of an 850 Special, perhaps needs to be an 81 also, it will have the same paint scheme and be completely indestinguishable unless you ride it and know where the revs should be. JAT.Life is what happens while your planning everything else!
78 XS750Comment
Hey Rick Thanks for posting the pictures. on the topic of final drive. I am used tothe XJ650 which turns about 1000RPM more than the XS11 for the same road speed. so my mod was to get an XS11
850 FD
Fork Brace
Oil Cooler
Throttle Lock
