Caveat emptor?
You sure about that? Let's see what Jim claimed for that bike:-
"it has new brakes tires 54000 km runs great carbs all done new carb boots and fork seals this bike needs nothing everything works this bike ride great"
Compared to what Rick sez about it:-
" - - Two floats had holes in them from rubbing on incorrect float bowls. We still need two bowls.
Head had two bent exhaust valves due to improper shims. - - - Used but serviceable valve springs donated by BDF. New valve seals installed
We replaced the timing chain as it had no adjustment room left. Stripped spark plug hole repair donated by Prong Built. - - -
Oil pan drain bolt female threads broken off. Pan had lots of sparkley bits inside, likely from trans. Oil pan donation BDF. - - -
Steering head bearings and races need changing Every other bearing on the bike needs to be checked, cleaned and repacked.
Fork seals need changing.
Rotors need to be cleaned up and checked as do pads, calipers and masters and fluid changed.
Middle drive and final drive oil change.
Needs Tires, mirrors, battery, fuel, oil and air filters, and mufflers
Exhaust pipes were welded with extensions, used stock pipes donated by BDF "
It's said that beauty is in the eye of the beholder but this is f**king ridiculous.
I went and looked at the first bike when he first posted it up here.
