emergency shut off tip over switch
  • b.walker5
    • Feb 2009
    • 1745
    • Invercargill, New Zealand
    Okay... What sort of switch is it? Has anyone opened it up. Looking at the wiring diagram I can see it's a NO switch that simply shorts the ignition module to earth, hence the reason the bike will run without it, but what does it consist of? Is it a mercury type device, or a simple rolling brass ball? or some other type of gravity switch? Mercury switches, unless broken are virtually bullet proof and most other gravity switches are fairly simple devices that should easily be fixed if not working.
      60 Degrees of Separation
      Brian, inside the tipover switch is a U-shaped, non-conducting bolt with a heavy metal ring over it.
      When the bike is upright the metal ring rests at the bottom of the "U" and doesn't touch any contacts.
      When the bike tips over or leans more than 60 degrees the metal ring slides along one leg of the "U" and grounds the ignition circuit, killing the engine.
      Regards,
      Scott
      • b.walker5
        • Feb 2009
        • 1745
        Okay, thanks Scott, it's sound like a variation on a simple rolling ball gravity switch and should be simple to fix. Most problems with this type are corroded contacts or stuck "balls". It's probably easier to disconnect than fix but if the safety angle is important then fixing it should'nt present any problems.
          Easier to photograph than explain
          The Tipover Switch
          Exterior of switch with upright position marked
          Interior of switch in upright position: there is no contact anywhere
          Interior of switch in tipped position: metal ring shorts contacts and grounds ignition
          Regards,
          Scott
          • b.walker5
            • Feb 2009
            • 1745
            Doesnt get much simpler than that... Not much to go wrong there.
              • 2117
              I don't even have one anymore.I saw one on e-bay the other day.Maybe i will pick one up.
                • 2117
                I found one on e-bay.
                • DenyP
                  • 599
                  • Staples, Minnesota 56479
                  I think it is a good feature. If it is missing on your bike or not functioning, please find a replacement. I dumpt my bike with the wife on board last year. My bike killed as designed. Could have been a problem had it not! I like this feature and it doesn't deminish man-hair to say so!
                  Deny
                    • 2117
                    Won my bid on e-bay for this part.Brand new-old stock,never used.
                    • andreashweiss
                      • 951
                      I have lots of those tipover switches in the parts pile if anyone ever needs one, thanx andreas
                        My XS's tipover switch works fine so far and I don't plan to remove it. In fact, I wish I'd had one twenty-five years ago on my KZ when it tried to crawl up my leg and eat my knee after a crash on Pacheco Pass. I got gnaw marks on my leg and a holy knee and I don't need The Weather Channel.
                        Regards,
                        Scott
                        • Rstyduck
                          • 107
                          Wish i had one on my 77 RM250 years ago.
                          Ok, had no kill switch either. Had to stall the bike to shut it off.
                          I was riding in the coulee's here and my throttle cable broke and jammed my carb wide open in third gear.
                          No way to shut it off, rear brake was non existent.
                          I rode it into the ground, literally.
                          Bike took off, i grabbed a handfull of front brake, went about 200ft before jumping onto a gravel road.
                          Once my front wheel got airborne the brake locked it up, once it touched ground, so did i with the bike on top of me trying to do Mach 2.
                          A friend saw what happened and came to my rescue. Rear wheel spinning wildly above my thigh. He pulled the plug wire off to kill it.
                          Thank gawd.
                          Towed me and my bike home with a peice of barbed wire tied to the back of his Husquavarna and to the handle bar of my RM.
                          • cywelchjr
                            XS-XJ Super Guru(Deceased)
                            • 4450
                            • Sacramento, CA
                            I know mine works fine. I tested it when I dropped it in the parking lot. Engine went right off. Kind of an embarrassing way to test it, but certainly affective (also affective at demonstrating the non-gas resistance of fresh paint )
                            • DannyB
                              • 17
                              • belvidere il.
                              just unplug it and throw it a way. bike shutting off if you dump it will be the least of your problems.
                              82 xj1100j
                              4-1 header
                              k&n air pods
                              accel coils
                              progressive rear shocks
                              dyno jet kit
                              79 xs1100es (love of my life) passed away
                              __________________________
                              fast is never fast enough
                              • Crazcnuk
                                • 2980
                                • Hinton, AB, Canada
                                Spoken like someone who has no concept of what 100hp can do to you when your pinned under that rear wheel.
                                '05 ST1300
