emergency shut off tip over switch
  • EXXXCESS
    • Mar 2009
    • 46
    • greene county ga
    I can't find my emergency shut off switch I missplaced it somewhere in my shop can I just put a jumper wire across the to and go without it?
    79 XS 1100 Special
  • Welsh1100
    • Apr 2009
    • 40
    • Fairfield, California U.S.A.
    Emergency shut-off
    By passing the shut-off may work..however I don't recommend it unless you are absolutely "stuck" somewherre. On my XS1100 "F" standard I bypassed the lighting reserve unit. So far I have had no problems with my electrical system by doing this. The shut-off feature is much more important. I was recently hit on the freeway and the bike went down on me. As designed...the engine quit and frankly I was glad it did. My leg was caught under the rear wheel. Try to find the original unit or replace it as soon as you possibly can. Ride safe!
    Kevin
    Some days you're the pigeon..and some days you're the statue/
    1979 XS1100f
    Saddle bags, small wind screen and non-original rear shocks. Otherwise..completely stock.
    • wa407mpp
      • Jul 2007
      • 717
      The main reason for the automatic emergency cutoff switch is to kill the engine if you break or grind a hole an engine case in an accident, it won't keep running and pump all the oil out of the engine, before you can hit the kill switch.
      Fastmover
      lion". SHL
      78 XS1100e
        Damn Kevin! I hope you came out of it OK!
          I know there are many people who have simply unplugged the tipover switch and left it off with no ill effects. Of course it means that the engine will not be automatically turned off in the event of a tipover. It will, however, run as usual with no other side effects.
          • Big Daddy Funk
            • 639
            • Brantford, Ontario, Canada.
            Bug's got it.
            I agree with bug. Mine decided to shut my bike down at really inconvienint times during hard cornering almost crashing me. Rather than replace it I just removed it, no jumpers required. If I crash, It won't be because of a tip over switch. I'll just have to shut it down myself. If I can't get up I doubt I'd be worrying about it anyway. Rick
            I May Be Crazy, But I Have A Good Time.
            Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily rider
            • EXXXCESS
              • Mar 2009
              • 46
              • greene county ga
              I know its a safety feature I just couldn't find mine. To me it doe seem kinda like a catch 22 kinda like seat belts I have cut dead people out of cars that were killed by them that would not have been if they didn't wear them and I've seen people ejected that should have wore their seatbelt likewise the safety switch is great but what if somehow it failed? I will try to find one or get one from andreashweis.
              79 XS 1100 Special
                Do you mean the eswitch on the right handle bar? or the "tip over" switch? Honestly, I have yet to find that tip over switch on a wiring diagram and have no idea where it is on my bike. There are alot fo bikes out there without one, and I would not lose alot of sleep about running wihtout it. If you get that far over, chances are you will do something to the bike that will kill it anyway, like short out the main fuse, or hit the handlebar e-switch, or slam a footpeg through an engine pan and drain out the oil. Not to mention the float bowls and jets get fairly confused on their sides for the fuel air ratio.
                I would not however feel very comfortable running without the one on the right handlebar. That to me is VERY handy to shut it off for safety situations.
                • Crazcnuk
                  • 2980
                  • Hinton, AB, Canada
                  The switch is under the gas tank, between the regulator and the coils. It's the one with an arrow and 'up' on it.
                  I don't believe it's possible to lean these things far enough over to trip that switch, well not while moving...
                  I also believe it's to protect the rider from being chewed apart by the rear wheel in an accident. These things had enough power to do serious damage.
                  Yamaha couldn't care less if you tore a hole in the crankcase and wrecked the motor, they have plenty more to sell.
                  '05 ST1300
                  • b.walker5
                    • Feb 2009
                    • 1745
                    • Invercargill, New Zealand
                    Didnt know I had one on my special but if I have it doesnt work. I had to hit the kill switch while under the bike a couple of months back, or my broken leg would've been a minced leg. If my foot had been standing up straight instead of lying on the road 90 degrees to my knee it would've been in the spokes and they were still turnin in third gear
                      Perhaps the PO of your bike decided he didn't need it?? Lift the fuel tank up and look between the frame bars in the center of where the tank usually sits. It's a black box that mounts to a cross-bar in that area. Since the bike will run fine without it, you might even find an vacant connector in that area if it's not there.
                      • b.walker5
                        • Feb 2009
                        • 1745
                        I'll check tomorrow..
                          • 2117
                          I took mine off a long time ago.I think it went bad and never replaced it.Don't even know if they are available new, but i do see them on e-bay occasionally,
                          • b.walker5
                            • Feb 2009
                            • 1745
                            If the bike doesnt need it to run, other than an actual tip over, how do we know if they're working??
                            • Crazcnuk
                              • 2980
                              Start the bike, pull the module off it's little rubber hook and tip it (switch) over on it's side.
                              '05 ST1300
