reviving an old beast
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    #61
    aptos
    Yeah I used to live in the flats down by the beach there , and I know its pronounced aptoss not aptoes , do they still have that cement boat out there?
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • xs1100rider
      • 62
      • thornton,co
      #62
      carb kits,m/c kit
      georgefix is a great supplier of parts,when i got my rebuild kit i contacted him about all the extra jets(110,120,125)and 42.5 pilots and he told me what jets i should be using(high alt)and even sent an extra set of 45s to match the mods i have done.
      79 xs11sf
      80 xs11g-bagger
      81 xs11g-project(trike/chop?)
      80 xs400 special(wife's trainer)
        • 7795
        Yes, it's in three parts, and you can no longer go out on it, but it's here. I think another twenty years, and it will just be a pile of something in the surf....
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          #64
          rubble
          I remember fishing off that boat but that was 19 years ago , boy how time flies , any way just ordered new float needles and seats, and petcock rebuild kits ,soon as I get those I will sync and mix and in the meantime do my brakes
          91 kwaka kz1000p
          Stock
            • 7795
            That's about when I was walking down with my two kids, and fishing off the boat as well! I worked swing shift, so I'd walk the two down with a stroller, fish for about an hour, and push everyone back up the hill. I lived off of Rio Del Mar Blvd. at the time.
            • GARTHXS
              • Nov 2007
              • 1631
              • Seattle
              #66
              where i stand
              So latest update , still waiting for parts and I am wondering about my fuel problems , petcocks leak and it seem so do the float valves. I've got new float valves on the way and rebuild kits as well for the taps , my method for checking the float valves is to blow into the bowl valves when the carbs are upright , is this a decent test? I cleaned all the float valve seats and needles with simichrome but they still seem to leak?? And any tips on petcock rebuilds??
              91 kwaka kz1000p
              Stock
                • 8863
                For checking the float valves for leaks, the bench test is the way to go. Read post #2 in this thread...
                  #68
                  Garth,
                  I used both of those test methods on mine. First the Prom method of upside down. Then with the bowls on and upside right check by blowing into fuel line/Tees.
                  I had a bit of an issue getting mine to seal, so I wanted to make REALLY sure.
                  • GARTHXS
                    • Nov 2007
                    • 1631
                    • Seattle
                    #69
                    thx
                    I'll try the prom method its semms like its worthwile and I am stalled out until parts arrive , any way all my brake stuff is here and I want to start on that, anybody had much experience with a mity vac , I am thinking of getting one which model would you reccomend??
                    91 kwaka kz1000p
                    Stock
                      • 7795
                      I have the "inexpensive" version of the Mighty Vac, and it works well. I use it on cars as well as bikes, and makes bleeding brakes a one man job. You can also use it to check vacuum operated parts, such as petcocks, advance unit, etc.
                        #71
                        I bought the $30 version form autozone to bleed my rear brakes. I also use it as my vacuum gage for synching my carbs.
                        • GARTHXS
                          • Nov 2007
                          • 1631
                          • Seattle
                          #72
                          brake down!
                          So I finaly got the brakes done , I was having a really hard time with the rear brake and wasn't having much luck, no flow at all , so I pulled the back half off the rear brake line and found out it was blocked , so I tried to ream it out with a guitar string and had no luck. Then I took half of the line from my parts bike(unclogged) slapped back together and SUCCESS. As for the front I had forgotten to tighten all the fittings on the new S/S lines. So fixed that and viola font and back done with mucho pressure so just waiting on new float valves and petcock rebuild kits and I should have the GO and the WHOA, next , fix headlight probably just a relay, and clean ,polish and redo the suspension and new tires and RIDE!!!
                          91 kwaka kz1000p
                          Stock
                            • 7795
                            So that being said, you WILL ride it on LoHo's June trip, so we can all drool over it??
                            • GARTHXS
                              • Nov 2007
                              • 1631
                              • Seattle
                              #74
                              damn work
                              Unfortunatly I will probably have to work. ;( . With that I will be stuck to day trips until maybe july. At least the 78 is running good , it is so nice to have a good running bike to hop on after wrenching on a project!!
                              91 kwaka kz1000p
                              Stock
                              • GARTHXS
                                • Nov 2007
                                • 1631
                                • Seattle
                                #75
                                runs good!
                                So got the new float valves and petcock rebuilds in and guess what no puddle of gas under my bike! Needs a little sync runs pretty good. Getting a little smoke from the left pipe and hoping it loosen the rings when I put a few miles on her. Still need to put on the footpegs on and sort out the headlight
                                91 kwaka kz1000p
                                Stock
