reviving an old beast
  • GARTHXS
    • 1631
    • Seattle
    #46
    28 years
    I was just thinking of taking some of the extra wire from my parts bike , the same type of flexable wire but just a little farther down the lead where its fresh. Do you think that stuff is bad?
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • GARTHXS
      • 1631
      • Seattle
      #47
      parts!
      I just got all my brake parts from pnm. Oh yeah! It looks xmas in feb just wish she was running. Hopefully thursday I will get to the pick up coils on my day off , and (fingers crossed) she'll fire up!
      91 kwaka kz1000p
      Stock
      • thewiz
        • Oct 2006
        • 1115
        • Wilksboro, NC
        #48
        Any new, highly flexible stranded wire ...
        in the correct size would probably be a step better than a chunk borrowed from a wreck .... what the Diver's talkin' about is one of those lead wires like on the multimeter that you got uses ... apparently R. Shk. sells 'em separately ... good one, Ray ....
        80G Mini-bagger
        Past XS11s
        • GARTHXS
          • 1631
          • Seattle
          #49
          radio shack
          So, replace the wires from the connection from the coils to the part where it goes into the sheath? How does it connect to the pick up coils? Solder or connecter? Oh btw just rebuilt rear m/c but the kit for the front doesn't fit - I guess the front isn't stock oh well I have a replacement on the way, just waiting till thursday for time off and daylight , I wish I had a garage
          91 kwaka kz1000p
          Stock
            • 7828
            I usually solder the new wire to the old. DO NOT cut the old too close the the coil, as it will be hard to get a good connection. If you have some GOOD flux, USE IT!! It will help the solder bond to the old, corroded wires. I also use a short bit of heat shrink tube to seal the connections. If you can find the Anchor brand marine grade, it has a glue that will make it water tight.
            • GARTHXS
              • 1631
              • Seattle
              #51
              anchor
              Where would I find that brand?
              91 kwaka kz1000p
              Stock
              • GARTHXS
                • 1631
                • Seattle
                #52
                I cant wait
                Till tomorrow its my day off and hopefully I can get the 79f running tomorrow. Any tips on soldering I have never done it before, I read some stuff online like tinning the tip of the iron , but anything else I should know. For the splice do I just crimp the wires together and drop some hot solder on it??
                91 kwaka kz1000p
                Stock
                • GARTHXS
                  • 1631
                  • Seattle
                  #53
                  hmm?
                  Just thinking of a name for the new bike
                  91 kwaka kz1000p
                  Stock
                    • 7828
                    Marine or boat supply. West Marine, Bass Pro, etc. should have the MARINE heat shrink tubing in stock. It has a heat sesitive glue on the inside, so it shrinks and seals. The warning is it is stiff, so you do NOT want to put a long piece on the wires, just cover the joint.
                    • GARTHXS
                      • 1631
                      • Seattle
                      #55
                      thx Ray
                      I do have west marine not far from me, btw where in santa cruz do you live , I graduated from sc high and also went to soquel for one year ! Maybe I should pay more attention to your signature, do'h!
                      91 kwaka kz1000p
                      Stock
                      • GARTHXS
                        • 1631
                        • Seattle
                        #56
                        its alive!!!!
                        Pick coil fix done , tried to start it, no spark so I pulled the tank and the ballast resistor was unplugged and so was the tci , fixed that turn key , push start and vavoom she fires right up obviosly needs a sync and such but what a feeling!!!!
                        91 kwaka kz1000p
                        Stock
                        • GARTHXS
                          • 1631
                          • Seattle
                          #57
                          what do i need now
                          It looks like I need new float valves, petcock rebuild kits and new tires and tc's fuse box omong other things!
                          91 kwaka kz1000p
                          Stock
                            • 7828
                            I actually live in Aptos. It's just not many people know about our little town.
                            Glad you have it running!
                            Unless the rubber on the petcocks is really bad, you should be able to just clean and reuse everything. Make sure the inside of the handle is polished, so it turns without "grabbing". Georgefix on ebay is a reliable source for complete rebuild kits for the carbs and brakes.
                            • thewiz
                              • Oct 2006
                              • 1115
                              • Wilksboro, NC
                              #59
                              How about ...
                              MOOSE ? What do ya' think?
                              80G Mini-bagger
                              Past XS11s
                              • GARTHXS
                                • 1631
                                • Seattle
                                #60
                                how about it
                                More like moose knuckle,hahah
                                91 kwaka kz1000p
                                Stock
