reviving an old beast
  • GARTHXS
    • Nov 2007
    • 1631
    • Seattle
    ok!
    Not much time today, I'm going to dump the gas and gear drives and that's about it , I guess I need to go shopping for chemicals
    91 kwaka kz1000p
    Stock
    ( Insert clever quote here )
    • GARTHXS
      • Nov 2007
      • 1631
      • Seattle
      done for the day
      Drained and refilled gearboxes to spec and drained the gas tank, took off the petcocks and very carefully disassembled them and managed to save all the diaphragms and seals cleaned em up reinstalled and they work fine so far (no leaks)
      91 kwaka kz1000p
      Stock
        Awesome, good to hear it worked out for you!!
        • GARTHXS
          • Nov 2007
          • 1631
          • Seattle
          whats next
          I installed a lockhart oil cooler , next is remove old carb boots , can I use liquid gasket to seal the newer ones?
          91 kwaka kz1000p
          Stock
          • GARTHXS
            • Nov 2007
            • 1631
            • Seattle
            brakes
            what is the best way to pull out caliper pistons?
            91 kwaka kz1000p
            Stock
            • petejw
              • 2269
              • sydney australia
              Garth,
              If the calipers are fitted to the hoses, slowly pump
              the brake lever and the piston will pop off, clamp that brake hose to remove the other piston.
              if the callipers are detached, u can carefully pump air
              into the caliper, wrap a rag around the caliper, they can
              literally shoot out.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • GARTHXS
                • Nov 2007
                • 1631
                • Seattle
                i dont have a compresser
                I think I have an extra mc , ill try that
                91 kwaka kz1000p
                Stock
                • petejw
                  • 2269
                  • sydney australia
                  Garth,
                  If they're not seized u could also grab a pair of vicegrips/multigrips
                  onto the piston and twist them out.
                  pete
                  new owner of
                  08 gen2 hayabusa
                  former owner
                  zrx carbs
                  18mm float height
                  145 main jets
                  38 pilots
                    • 8962
                    Removing caliper piston
                    A nice trick I figured out last time I had to do that... Take a valve stem from a car tire and whittle down the rubber on the base end until you are able to thread it into the banjo bolt hole on the caliper. Take a bicycle pump and slowly pump air into the valve (bleeder screw closed of course) and the piston will come right out. It's nice because you can slowly pump air in versus compressed air, and your hands and face can be away from the piston. Works well with not too much brake fluid flyin' out. The rubber valve stem makes a nice air tight seal.
                    • GARTHXS
                      • Nov 2007
                      • 1631
                      • Seattle
                      bike pump
                      How did you ever figure that out? I would have never thought of that
                      91 kwaka kz1000p
                      Stock
                        • 8962
                        That's actually the same idea as a makeshift car radiator pressure tester. Use that shaved off valve stem and insert it into the overflow hose at the radiator cap, pump it up a little, and check for leaks. Been doin' that for 25 yrs. and I'm still too cheap to buy the real tool, lol.
                        • GARTHXS
                          • Nov 2007
                          • 1631
                          • Seattle
                          cheap
                          Why waste money on tools when you can spend it on parts! Haha
                          91 kwaka kz1000p
                          Stock
                          • GARTHXS
                            • Nov 2007
                            • 1631
                            • Seattle
                            frozen
                            Any tips on getting out seized brake pistons
                            91 kwaka kz1000p
                            Stock
                            • petejw
                              • 2269
                              • sydney australia
                              you can try placing a piece of wood over the piston
                              and give it a few 'waks' with a hammer, then try twisting the piston with some vice grips, or use compressed air as stated before.
                              Ive also heard of ppl pumping in grease into the piston, but ive never had to try this.
                              pete
                              new owner of
                              08 gen2 hayabusa
                              former owner
                              zrx carbs
                              18mm float height
                              145 main jets
                              38 pilots
                                • 8962
                                Soaking piston with PB Blaster may help. Let it sit awhile.
