I too am doing the 2nd gear fix
  • renegade_xs11g
    • 462
    • Mid-Michigan
    Diver: Man you type fast....I hadn't even started.....
    Bug....definetly start with Divers
    but I remember that TC had a similar situation when he helped with "madmax" I think,
    My Photo Bucket
    • CatatonicBug
      • 6117
      • Clinton, UT
      Ok, I adjusted the screw at the clutch cover, and that tightened things up, but now it's REALLY tight. I don't feel any movement when I squeeze the grip. The grip moves, but it almost feels like I'm just stretching the cable or something. Definitely not as smooth as it was before I opened this can 'o worms.
        Check that you did not get the cable bound up in the handle when you gave it slack. The barrel may have slid up and the cable not be in the groove properly, or perhaps the cable got twisted when you had it pulled out of the case and the routing is not as it should be?
        • Ivan
          • Jul 2008
          • 2524
          • Hutchinson KS
          Did you get the clutch lever back in the right position when you installed the cover? It has three possible positions and only one is right.
          You just said there is nothing. Does that mean the the handle pulls in but the clutch doesnt disengage, or does it mean that the clutch wont engage at all?
          Keep your chin up, we'll get it figured out.
          Ich habe dich nicht gefragt.
          • CatatonicBug
            • 6117
            • Clinton, UT
            I figured it out, but it's not a happy thing... Evidently, when I was tightening down the clutch spring bolts, the "sproing" I felt wasn't just something slipping into place. I took the side cover back off, and the cluch just was not moving at all. I started to unscrew the bolts to see what happened, and I was able to unscrew all of them without the plate letting go! I tapped on it, and it jumped into my hands, along with all the springs, and one of the posts that the springs ride on!!
            The post must have snapped when I was tightening it down, and it made the cluch bearing sit in the raceway at an angle, not allowing it to slide in and out. So, now I need a new "Pressure Plate #2". This is what I get for feeling confident, I guess...
            • petejw
              • 2269
              • sydney australia
              broken post
              Hey Catatonic,
              there should be a post about fixing a broken post
              on the star plate, from memory the broken post was
              drilled and tapped, then secured with a bolt.
              keep at it, you'll get there.
              pete
              new owner of
              08 gen2 hayabusa
              former owner
              1981 xs1100 RH (aus) (5N5)
              zrx carbs
              18mm float height
              145 main jets
              38 pilots
              • petejw
                • 2269
                • sydney australia
                try this link
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • CatatonicBug
                  • 6117
                  • Clinton, UT
                  Unfortunately, mine did not break off clean at the base. The whole base broke out. To be honest, I wouldn't trust any repair on that kind of a break, unless it was professionally welded.
                    • 8893
                    Send Andreas a PM, he probably has one.
                    • CatatonicBug
                      • 6117
                      • Clinton, UT
                      Yep.. Already done. Now I gotta wait for the USPS to do it's job. I hate waiting!!
                        • 7819
                        If Andreas cannot help, let me know. I prefer you try him first, as that is how he makes ends meet. I do have a spare clutch, and I WAS going to save it "just in case". But IF you cannot get one quickly, let me know via PM and I can send it out.
                        • CatatonicBug
                          • 6117
                          • Clinton, UT
                          No, I'm going with Andreas. He's got it. I just hate waiting for stuff. It's supposed to be in the 50s tomorrow, and I'm gonna have to share the cage with SWMBO again. It's all about instant gratification! Too bad you can't e-mail parts...
                            • 1987
                            found this listing on the bay..... http://cgi.ebay.com/ebaymotors/1980-...em110349030714
                            • Ken Talbot
                              • 4251
                              • Revelstoke, BC
                              Would the fact that I took the clutch basket out and put it back in require additional adjusting?
                              Apparently yes!
                              Ken Talbot
