My New Project Build (Pictures)
  • XSPastor
    • Oct 2007
    • 602
    • Gaithersburg, MD
    More springs...
    ebay springs
    more ebay springs
    Tim Ripley - Gaithersburg, MD
    23mm float height
    120 main jets
    42.5 pilot jets
    drilled stock airbox with K&N
    Jardine 4 to 1 Exhaust
    spade fusebox
    1st and 2nd gear fix
    • turbo3g
      • 59
      • Alachua, Florida
      Thanks for the links but my springs are not OEM. there the progressive ones that are an inch shorter than stock.
      http://i25.photobucket.com/albums/c7...D/IMG_0195.jpg
      http://i25.photobucket.com/albums/c7...D/IMG_0190.jpg
        • 8797
        grit
        You could try some 320 to get the rust off the springs. I've taken the springs off the shocks to clean them using a wire wheel on an extension to get the rust off the inside. To do that, you'd have to rig up a spring compressor to dissasemble them. Depends on how far you want to go cleaning them. Painting them black is also a good option, it'll hide the chrome pitting.
        • tarzan
          • 1700
          • Chandler,Az.
          My springs were worse than those ones and I used grade 0 and grade 1 and a lot of elbo grease and they look great now.The chrome on the oem springs seems to be fairly heavy.At least on mine.
          80 SG XS1100
          14 Victory Cross Country
            • 8797
            shock spring compressor
            Homemade motorcycle shock spring compressor. Semi-safe.
            • Ivan
              • Jul 2008
              • 2524
              • Hutchinson KS
              did you end up using the Plastex for the side covers? what do you think of it?
              Ich habe dich nicht gefragt.
              • blackchop2
                • 93
                if you decide to get rid of those homemade steel sidecovers i be into those .
                let me know.
                • XSPastor
                  • Oct 2007
                  • 602
                  • Gaithersburg, MD
                  One man's trash...
                  23mm float height
                  120 main jets
                  42.5 pilot jets
                  spade fusebox
                    Hi Turbo,
                    my best guess about those orphan carbs is they came off a V4 Honda.
                    The clue is the push-pull throttle cable half-moon between the carbs.
                    • turbo3g
                      • 59
                      • Alachua, Florida
                      Ivan I actually ended up using JBweld.:P I use it for every thing and it works great!
                      I dont want those metal side coves so i'll let them go for $35 shipped
                      those carbs looked like they were for a Honda:P
                      • turbo3g
                        • 59
                        • Alachua, Florida
                        update!
                        well here are some pics of what i have done so far.
                        I'm talking it all apart and going to have my buddy who airbrushes do a custom paint job on it. I need to know how to make the engine look better?
                        can I Just get a very fine metal wheel and scuff it down?
                        I also relocated my license plate
                        it looks better there:P
                          • 8797
                          Easiest way is to scuff it, powerwash it, and then paint it with hi-temp rattle can. I've done 3 that way and they look like new.
                          • blackchop2
                            • 93
                            i repainted my engine high temp black. ill be adding polished engine bolts to it. might even sand down just the fin ends .
                            or you could take the time to polish and paint however you like.
                            reason i go black is because it just looks cleaner is all .
                            plus im not much of a chrome whore lol
                            • turbo3g
                              • 59
                              • Alachua, Florida
                              Lol I'm not a chrome fan eather. I just want to polish it I guess. What are your recomendations? Do I need polishing compound? Or is there some tool or device that I can use to make it look clean. It doesnt have to shine, it just has to look good:P
                              Ty
                              • blackchop2
                                • 93
                                clean degrease then there are several ays of "polishing"
                                i use 'mothers' polishing compound.- works great and it takes less time messing around .
                                or you could use polishing wheels with compound. they sell different wheels for your grinder or drill.
                                depends on if you have the patience to shine it up.
                                i dont so i just reach for the high temp black and call it done in a few minutes lol
