My New Project Build (Pictures)
  • tarzan
    • 1700
    • Chandler,Az.
    #61
    Tahts gonna look nice.It should sand out nice.One thing I found out about sanding clear is,you want to sand it pretty soon after it dries.It gets really hard the longer it sits.It took me a week to do my daughters car.It had some runs and a little orange peal too.But it came out nice.
    80 SG XS1100
    14 Victory Cross Country
    • turbo3g
      • 59
      • Alachua, Florida
      #62
      yea i know.. the guy who is doing it is working on the art work as I type this.
      http://i25.photobucket.com/albums/c7...D/IMG_0195.jpg
      http://i25.photobucket.com/albums/c7...D/IMG_0190.jpg
      • digitalsam
        • Aug 2008
        • 208
        • Carlsbad, NM
        #63
        Heat and a painted engine?
        [QUOTE=turbo3g;187432]Well I started reading about polishing... and thought why do all that work once a year?....or spend $10 and paint it black and call if a day!! pics don't do it justice
        I was reading that painting an aluminum engine reduces the aluminums ability to cool itself. (disipate heat) Has anyone had any problem with that?
        I am painting the frame an aluminum color with cast iron grey tank and sides. I am thinking that a black engine would make it all pop? But living in 110 degree weather, I need all of the cooling ability I can get.
        You bike looks nice BTW.
        Sam Christensen
        The Chronicles of my Rebuild http://xs1100rebuild.blogspot.com
        If you are leading and no one is following, maybe your just taking a walk.
        Currently bikeless. Sold my 1980 XS1100 Special
          • 8962
          [QUOTE=digitalsam;192090]
          My engines are painted with 1200F ceramic paint, aluminum color, not black. No problems for me with the engine overheating. It gets very hot in my area too.
          • digitalsam
            • Aug 2008
            • 208
            • Carlsbad, NM
            #65
            Painted Engine
            Cool, I am going to paint the engine. Any tips? Light Coating versus heavy? Prep secrets? Special prayers for the occassion? etc...
            Sam Christensen
            • turbo3g
              • 59
              • Alachua, Florida
              #66
              what I did to prep for paint was presure wash the engine to get all the 30 years of crud it had on it. them I let is dry and used acidtone to wipe it down and then used high heat primer.. then paint
              I'll have to test for temp problems after i get the bike back on the road.
              • tarzan
                • 1700
                • Chandler,Az.
                #67
                You know,
                All our bikes have paint on the engine.Its clear ,so it wont oxidize.So I dont think color will hurt anything as long as you dont put a 1/4" thick on it.
                80 SG XS1100
                • digitalsam
                  • Aug 2008
                  • 208
                  • Carlsbad, NM
                  #68
                  Curing High Temp Paint
                  Onthe VHT High Temp paint can, it says that I will need to cure the paint by cooking it in an oven at 250, 300 and some much higher temp consecutively.
                  I know that aluminum warps when you heat it. The question is at what temperature does is warp. Has anyone else "cooked" their engine? and what did your wife have to say about a "XS roast" in her oven?
                  What will happen if I don't cook it? My wife is not really keen on the idea.
                  Sam Christensen
                  • petejw
                    • 2269
                    • sydney australia
                    #69
                    not sure at what temp the head would warp at,
                    but you'd be sweet putting it in the oven, itll stink
                    so dnt know what your wife will think of that. :-)
                    You can install the head if you let it dry for a few days,
                    perhaps leave it in the sun,
                    but the paint will be soft and can scratch easily. The engine heat would then cure the paint.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    1981 xs1100 RH (aus) (5N5)
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                    • blackchop2
                      • 93
                      #70
                      you dont have to heat or bake the vht painted engine- once you run the bike the engines heat will cure the vht paint.
                      and painting an engine doies not make it dissapate or hold more heat in .
                      • Wildkat
                        XS Special Gurette
                        • Apr 2004
                        • 3416
                        • Location, Location
                        #71
                        I used VHT on my FJ engine and just let the engine temp cure it...
                        That was a few years ago and it's still holding up very well...
                        81 SH Something Special
                        79 SF MEAUQABEAUXS
                        81SH Nor'eas tah (Old Red)
                        80 LG Black Magic
                        78 E Standard Practice
                        James 3:17
                        “Alis Volat Propriis”
                        Yamaha XS 1100 Classic
                        For those on FB
                        • Shappers
                          • Sep 2006
                          • 158
                          • Helsinki, Finland
                          #72
                          I have an old oven in my workshop and I have been baking everything that I have sprayed at 150°C / 300°F for one hour.
                          I haven't had any problem with warpage or sleeves dropping out of the barrels. Only problems have been that the crankcases don't quite fit in the oven so you need to keep rotating them to keep the heat even
                          BTW. I have been using PJ1 gloss black for everything
                          '84 Sport
                          • turbo3g
                            • 59
                            • Alachua, Florida
                            #73
                            dham you guys have done some nice arss painting..
                            mine looks like crap.. I've been waiting on the tanks and tail for a while thats why I have not been on here..
                            I've been busy turbocharging my eclipse.
                            i just spent a crap load of money on my car. i feel like I need to get this bike done so I can sell it.
                            i'll see how I feel about the bike when Im done.
                            • Korr
                              • Jul 2008
                              • 293
                              • Torrance, CA
                              #74
                              yeah the engine will cure itself with regular use. Before it fully cures it will smoke and stink ALOT ehhehe
                              1978 XS1100E Standard
                              Tkat Fork Brace
                              On Hold
                              TopCat S.O.F.A. + Fuse Block
                              Mike's XS Pod FIlters
                              • turbo3g
                                • 59
                                • Alachua, Florida
                                #75
                                ^yea man that stuff really stinks!
                                I used it on my pips and it stunk for a couple of days.
