Fuel Line Length
    • 2117
    I never know if i will take the bike or Jeep to work,therefore the bike always has gas in it.The stations around me are usually closed by the time i go to work and the ones that are opened all night are not on my way to work.
    • MrOzz
      • Aug 2008
      • 782
      • Massachusetts
      I have always filled up long before I get the low fuel warning light. Awhile a go I had run out of fuel on a friends bike cause his light was broken. Luckly it died 1/4 mile from the gas station. So out of habbit I fill up when ever I take the bike out.
      1980 XS 1100SG
      Dyna 3 Ohm Hi Output Coils
      Pod Filters
      DynoJet Kit
      T.C.'s Fuse Block
      V-Max Auto CCT
      • egsols
        • Jan 2006
        • 1090
        • Barrie, Ontario, Canada
        Kinky
        I use a couple of compression springs over my lines to keep them from kinking. The local hardware store has lots, I got ones about 1 1/2" long with the id just bigger then the lines.
        Ernie
        • MrOzz
          • Aug 2008
          • 782
          • Massachusetts
          Re: Kinky
          Aaaaaa A great idea egsols. I will give that a try also.
          Ozz
          1980 XS 1100SG
          Pod Filters
          DynoJet Kit
          T.C.'s Fuse Block
          V-Max Auto CCT
          • Toolmaker Tim
            • 671
            • South Bend, Indiana
            Maybe a stupid question
            Do 80 carbs have individual connectors? The reason I ask is you said you have 4 fuel lines. My 79sf only has 2. Am I missing something?
            1979XS1100SF
            K&N's and drilled airbox
            Jardine 4in1
            Dunlop Elite 3's
            JBM slide diaphragms
            142.5 main jets
            45 pilot jets
            T.C.'s fusebox & SOFA
            750/850 FD mod.
            XV 920 Needle Mod.
            Venture Cam Chain Tensioner
            • planedick
              • Mar 2005
              • 2068
              • Yorba Linda, California
              Two are vents
              I hope someone hasn't hooked fuel lines to the upper ones!!!!!!
              Drilled airbox
              Tkat fork brace
              Hardly mufflers
              late model carbs
              Newer style fuses
              Oil pressure guage
              Custom security system
              Stainless braid brake lines
              • egsols
                • Jan 2006
                • 1090
                The reason for four fuel lines is the front tap on the petcock was designed to provide a prime circuit that supplied the carbs uninterupted fuel whereas the rear tap fed a vacuum shutoff (octopus). Many owners have removed the octopus and then capped the prime tap leaving only two fuel lines.
                Tim, check your tank, you will probably find the front taps on your petcocks are capped.
                Ernie
                • MrOzz
                  • Aug 2008
                  • 782
                  • Massachusetts
                  The reason for four fuel lines is the front tap on the petcock was designed to provide a prime circuit that supplied the carbs uninterupted fuel whereas the rear tap fed a vacuum shutoff (octopus). Many owners have removed the octopus and then capped the prime tap leaving only two fuel lines...
                  Is it better to get rid of the octopus? What are are advatage/disadvantage of doing so?
                  Thanks,
                  Ozz
                  1980 XS 1100SG
                  Pod Filters
                  DynoJet Kit
                  T.C.'s Fuse Block
                  V-Max Auto CCT
                  • egsols
                    • Jan 2006
                    • 1090
                    Its a matter of preference.
                    Some get rid of it when it starts leaking, rather then rebuilding it. Myself I did away with it to make the plumbing cleaner and add in line filters. Once you do get rid of it, you should remember to turn your petcocks off, just in case a float sticks or a float valve/ oring leaks.
                    Some like to keep the bike stock so they leave it on..."if it ain't broke don't fix it"
                    Ernie
                      Originally posted by MrOzz
                      Is it better to get rid of the octopus? What are are advantage/disadvantage of doing so?
                      Thanks,
                      Ozz
                      Advantages: You don't have to manually turn your petcocks off, therefore the carbs can't overflow(providing they are operating correctly)and dump gas in the oil
                      Disadvantages: Leaks(possible fire), fuel starvation, makes the carbs just a plain B!tch to work on, parts to rebuild are either unobtainable or don't fit correctly, POS, etc.
                      JMHO
                      • Montreux_Blue
                        XS-XJ Guru (Deceased)
                        • 1143
                        In the petcock rebuild came the rebuild for the octy. I like it personally, my last bike was fuel injected so trying to remember to turn off the fuel is hit and miss with my memory! I say rebuild it and keep it, makes life easier.
                        Famous Myspace quote:
                        • Toolmaker Tim
                          • 671
                          Prime outlet
                          Ernie, Yes my prime outlets are plugged ,because I simplified the hose routing. Previously I had the 2 outlets tee'd together then run to the carbs. It was a PIA so I plugged the prime line. I didn't know MrOzz a octy, hence the question about the 4 fuel lines. I was concerned, like Dick, that the vent lines were hooked to fuel lines. That was worriesome.
                          Hey Dick, how you feeling. Still healing ok?
                          1979XS1100SF
                          Jardine 4in1
                          Dunlop Elite 3's
                          142.5 main jets
                          45 pilot jets
                          750/850 FD mod.
                          XV 920 Needle Mod.
                          • CheckMark
                            • Jul 2010
                            • 15
                            • Just West of the Atlantic Ocean in sunny southern Oregon
                            Fuel line Routing XS1100
                            Found this on the bottom of a 1979 Special seat pan.
                            79 SF ; 77 XS650D
                            • jwhughes3
                              • 2798
                              • Home of the Alamo
                              Thanks for reminding me of Jeremy...
                              I saw his old post from this resurrected thread.
                              John
                              '81 XS1100H - "Enterprise"
                              • BowlingSS
                                • Apr 2015
                                • 398
                                • Lawrenceville, GA.
                                What does everyone use to tap off the primary tap?
                                Bill
                                Jardine Spaghetti with Harley Mufflers
