what spark plugs do you use?
  • powerram50
    • 92
    • portland,oregon
    #46
    i used champs in the d-50 when i first got it and they did not last very long but my ngk's have been in there for years,and are still good.i pull them out once in awhile hit it with carb cleaner,a wire brush on my drill and then check the gap.
    81 SH for 300 bucks,work in progress.
    87 dodge d-50,35's,lockers fr&rr,fun.
    87 dodge d-50,35's,open diffs,wifes.
    89 dodge spirit,low 17's 1/4mile w/o turbo.
    • tiredoffixing
      • Mar 2008
      • 89
      • Ohio
      #47
      I use Denso and have not had a problem withthem
      • tiredoffixing
        • Mar 2008
        • 89
        • Ohio
        #48
        • JRocket
          • Jun 2008
          • 34
          • Ft. Myers, Florida
          #49
          I usually run NGK's, but was in a hurry to get plugs just to try to solve a problem running. Later, rebuilt the carbs and the Autolites are still in. Runs smoothly, so I didn't change them.
          What kind of mileage do you guys get? With my fairing, box, bags, and 225lb me on the bike, I only get about 33 mpg. Does anyone get the 47 that they tested back when the bikes were new? That's the reason for the 5th gear mod interest.
          John Rosko, Riding for Jesus! Make Him Lord of your life!
          • LoHo
            • Sep 2002
            • 1341
            • Fresno, CA
            #50
            Which Bosch plug works in the XS11?
            • UncleSpot
              • Jun 2004
              • 383
              • Home: Stockton, California Shop: Lodi, California
              #51
              which Bosch spark plug works in the XS11
              I've been using the Bosch Platinum WR7DP (4216) since I brought my '80 Special home - 'never had ANY problems with it, and I have more power than I know what to do with
              __________________
              Ron Veil
              <Ron_Veil@yahoo.com>
              1980 XS1100SG
              • Montreux_Blue
                XS-XJ Guru (Deceased)
                • 1143
                #52
                Now that I have the NGK iridium plugs, I now have a lot of wheel spin through 1st and 2nd gears. Tire has plenty of tread left, so what would be a better tire than the Dunlop 491 for traction?
                Famous Myspace quote:
                • UncleSpot
                  • Jun 2004
                  • 383
                  #53
                  I was just about to order some spark plugs for my XS11 and they stopped carrying the Bosch 4216 at Kragen's (down the street from my shop) so I thought after reading this thread to go to eBay and order some...
                  Found a GREAT price at R&R Import Parts in Union City, California
                  ( http://www.rrparts.com/index.html )
                  $7.25 for 4 plugs, $6.50 for shipping.
                  the plugs were here THE next day.
                  I won't buy my plugs anywhere else again.
                  I was so pleased with their speedy shipping I decided to call them and ask if they could get the NGK BPR6EIX iridium plugs - they can get them in ONE day... they're NOT cheap ($7/ea) but if they're 1/2 as good as everyone says I'll try a set.
                  __________________
                  Ron Veil
                  1980 XS1100SG
                  • UncleSpot
                    • Jun 2004
                    • 383
                    #54
                    Man, did I screw that up....
                    I paid $7.25 for EIGHT (8) spark plugs - NOT 4
                    (I didn't see my mistake until it was too late to 'edit')
                    __________________
                    Ron Veil
                    1980 XS1100SG
                    • fabricgator
                      • Feb 2010
                      • 67
                      • Treasure Coast, Florida
                      #55
                      Gotta throw a nickle in here and see what it gets me....
                      The Iridium plugs are high mileage plugs in that the cathode is made of Iridium and will not deteriorate over long continuous use. Thus making the needed re-gaping requirements unnecessary for longer periods of use. To change the sparks on my Mitsubishi requires removal of the intake system, Iridium plugs are specified and will last for 100,000 miles. Mine went 130,000. I will say at 130k, they looked beautiful, but I was not going to pop them back in. The new ones did not change my mileage or my power.
                      The heat range of spark plugs is not the heat of the spark but the spark plugs ability to dissipate heat through the plugs porcelain... this is achieved by the length of the cathode nose inside the plug. A hotter plug retains the heat and runs at a hotter operating temperature.
                      Kurt
                      I have a parking problem everywhere I go....
                      2001 Mitsubishi Montero
                      1987 944 n/a
                      1979 Titan
                      1979 Yamaha XS 1100 SF
                      1984 Suzuki SP 250
                      1987 Santana 23
                      1944 Aeronca L-3B Grasshopper
                      If it fly's, float's or fornicates..... your better off having a lease!
                      • jmnjrpa
                        • Jun 2009
                        • 863
                        • Lewisville, Texas
                        #56
                        E3
                        They are expensive but you will never go back. No other plug even gets close.
                        '81 1100 MNS - "Midnight XSpress"
                        Original except:
                        Big John
                        • ManitoulinLad
                          • 358
                          • Manitoulin Island,Ont.,Canada this is in Lake Huron
                          #57
                          You guys got a good deal on the irdiums @ $7.00 a piece. Up here I payed $50 something for a box of four. Long story but I've bought 2 boxes since they came out - But as stated they are great & the last plugs you'll buy for quite awhile, maint free. Ran them also when I had an XS650 - really made a difference in that bike. - Dan
                          '81 XS1100 LH - Midnight Special - been lookin' a long time for this one.
                          1179 big bore kit, 80SG motor
                          Rebuilt head, valves
                          TC Bros Forward Controls (Brass Pegs)
                          Tkat Fork Brace
                          T.C. Spade Fuse Box
                          Dyna Coils & wires
                          Mikesxs shocks,controls,& bars (special)
                          ISO grips with stelleto ends
                          4 into 1 black Bassani exhaust
                          Bridgestone Spitfires
                          Tuned by Tinman905
                          & a will to keep it.
                          • 81xsproject
                            • 3185
                            • Fortuna, CA
                            #58
                            Still running the Bosch P4+. They didn't seem to do much with stock coils, iggy, and carbs. However, after the DIS and the FI, they made a noticable difference.
                            '81 XS1100 SH
                            Sep. 12th 2015
                            RIP
                            • tinman905
                              • Aug 2007
                              • 946
                              • Orangeville,Ontario ,Canada
                              #59
                              Dan next time you're off the island stop into "Crappy Tire" they sell them there a bit cheaper than $50.00 .
                              BDF Special
                              • Steelhorse
                                • Apr 2010
                                • 2
                                • New Port Richey, FL
                                #60
                                Another vote for the NGK Iridium
                                Probably still a week or two away from getting my (first) XJ1100, but I thought I'd throw my 2 cents in. I've had the Iridiums in my '82 XJ750 for years. I've already ordered a set for the XJ1100 I don't even have yet! Never had a fouled plug in the XJ750. As a result of my good experience in the XJ, I put Iridiums in my RD400. Now, despite it's issues (and I don't know if I'll ever really get it "dialed in"!), I've never fouled a plug! Wouldn't believe it if I hadn't lived it...
