MPG and modifications poll
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    #121
    Mountain run
    I don't feel to bad about my mileage after reading through the posts here. I made a 127 mile run this last weekend up to the Mt St Helens viewpoint. A lot of minor uphill running, and corners. Slow running at about 50 MPH and down. I got home, and filled her up with 3.1 gal.41 MPG. Completely stock bike with no load except my fat _ss at 240 lgs. It was a warm day at about 80 in the mountains.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    • MotoMartin
      • Feb 2007
      • 26
      • Oceanside, CA
      #122
      I get 30 to 35 mpg, mostly short rides, errands, stop and go traffic, some freeway. Stock except for Mac 4-2 exhaust. Probably needs a carb sync, had the bike 18 years, have yet to sync the carbs. Smells a bit rich too.
      1979 XS 1100 Standard (project)
      1982 Honda CX500 Turbo
      1995 GSXR750 Streetfighter (project)
      1978 XS 1100 E (Sold) Owner for 19 years
        • 2117
        Went to take bike out for a ride today-Went before i filled up 60 miles and went to fill up and it took a little more than 2.5 gals to fill it up.I don't know what that means but am getting around 35 miles + per gallon
        • Crazcnuk
          • 2980
          • Hinton, AB, Canada
          #124
          Went on a cruise up to Maligne Lake, Saturday, with a couple firends. Wasn't doing a fuel mileage run, or anything but got 50.45(imp) or 42mpg(US).
          Haven't done any tuning since the top end rebuild, in May, but each run out the milage improves, and oil consumption is down.
          '05 ST1300
          • 81xsproject
            • 3185
            • Fortuna, CA
            #125
            Tuning the FI makes it very difficult to get decent mileage. However, even being on the throttle hard and often and never cruising less than 75 I noted the best mileage the bike has ever gotten the other day; 38mpg. I am very confident that if I could stay out of the throttle, I would be getting mid 40's.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
              #126
              My XS11SG is stock except for UNIpods replacing the airbox and re-jetting to 120s. Plus the bike is hauling a sidecar and the average sidecar rig has worse aerodynamics than a housebrick. 27mpg highway, same as my 3.8 litre Buick.
              Mind you, around town the rig still gets 27mpg while the Buick is down to 20.
              • Athedra
                • Oct 2009
                • 221
                • Benoni, South Africa
                #127
                Modification that dropped the mpg's is the FD. The jetting is different to compensate for the cones (pods), and the exhaust is a Cowley 4-1.
                I am still thinking my carbs are out of sync, but that is left for another threat.
                '79 XS1100 (2H9) named Bones
                1196 Big Bore
                4-1 Cowley exhaust
                750FD Conversion
                Echlin 54mm Racing Cones (Americanese = pods)
                Black Ebony Bottled glazed Tank (To be redone now)
                BMX footpegs
                Tank internally lined (Professionally this time)
                GSX400 Throttle bodies (Under serious investigation)
                Anti Sticky float bowl system
                • 03mach1
                  • 114
                  • Cuba, NY
                  #128
                  I got a new bottom airbox (Stock) and drilled 2 - 1" holes on corners (outside of the filter to help it breath better, since I put a K&N in. Best previous was 32.5MPG, last 2 tanks were 33.5mpg. That is with 140 mains (mine is a 1978).
                  It seems to work for me. WHen I bought the bike, it only got like 25mpg, before I rebuilt the carbs. I think I need to adjust the valves, it seems to rattle quite a bit.
                  Dave
                  • oseaghdha
                    • 1075
                    • N43.02.5,W88.14.2
                    #129
                    If you perforated the box outside of the filter element, you are allowing unfiltered air into the engine. The area inside the filter element is the dirty air, and this is the place additional holes are added.
                    XS1100SF
                    XS1100F
                    • Athedra
                      • Oct 2009
                      • 221
                      #130
                      Forgot to say, I am getting 18 km per liter. Someone on another thread worked it out to be 43mpg, and says it is good mileage over there. Over here it is also good mileage.
                      1196 Big Bore
                      4-1 Cowley exhaust
                      750FD Conversion
                      BMX footpegs
                      • tinman905
                        • Aug 2007
                        • 946
                        • Orangeville,Ontario ,Canada
                        #131
                        That was me in metric my kilomage (new word) was just over 15 km/litre but that is with a full bagger set up and my pork butt too!
                        It's nice to know I might be able to improve my kilomage
                        BDF Special
                        • mxmikie
                          • Aug 2008
                          • 482
                          • Bouse az
                          #132
                          my 1978E has a kerker and a 750 final drive honda coils w/marine wires and i dont go to reserve until 180 miles before i had to go to reserve at 100 miles
                          • jmnjrpa
                            • Jun 2009
                            • 863
                            • Lewisville, Texas
                            #133
                            Really odd
                            Just checked and I barely put 1.85 gallons in at 79 miles. That figures at more than 42 MPG in the DFW quagmire. Someone is doing something wrong or I have it running right. What is so odd is that I haven't tried to tweek it yet. I have a hiccup (or burp) from my 4th cylinder at mostly under 2000 RPM. Never had a colortune or anything more than a homemade Sync tool on it. My idle is at 800 (don't like it there). Have not done the 750 mod yet (I have an idea on that one in new thread). Still running the original coils and plug wires. I drive like I'm burning money. So how am I getting between 42/45 MPG? Just curious.
                            Maybe I should have done the 750 mod then I would have seen real MPG!
                            '81 1100 MNS - "Midnight XSpress"
                            Original except:
                            Big John
                            • dbeardslee
                              • 4385
                              • Maineville, OH
                              #134
                              Mine gets around 42 on the highway. Zipping from stop light to stop light it drops to around 30. Driving style has a huge impact when it comes to mpg's. Were you spending a lot of time on the big roads?
                              • jmnjrpa
                                • Jun 2009
                                • 863
                                • Lewisville, Texas
                                #135
                                oh ah,
                                65 to 95 on the freeways but quite a bit of traffic light stuff too. Maybe 60/40 counting in a couple of double downshift (to triple digit) rip and roars. Oh, yeah and one brief shower.
                                Original except:
                                Big John
