I've done compression tests, 120-125 for all 4 at 3500ft.
I checked the diaphragms, at first it would take betwen 8 and 12 seconds for 3 of them to drop, the other would, more or less hang, there until you let your finger off the hole. I used some Lubriplate to help them seal, and now they will all stay there until you release them. (they are coming down, but VERY slowly).
My problem is top end. There is virtually none. My bike runs out of power in 4th and 5th gear at around 6500rpm.
Mid range is good, low range is now a bit boggy, it feels like I am starting in 2nd gear. When I lower the needles one notch, the bog goes away.
I've tried 110's (stock), 115's and 120s. All had the same top end problem. The 115s seemed to run ok, but the 120's were very rich in the mid range. At the time I had #45 pilot jets. Now I have the stock 42.5's.
