It looks to me like it is lean at the top too, but when I went to the 120s the midrange got VERY rich.
If I drove at 4000 or less for any more than a few minutes, the bike would load up big time. I would have to drop a gear and roll around at 5000+ to clear it out.
For whatever reason, the PO had 45 Pilot jets, with stock mains. This would have added to the low-mid richness.
What was happening, I believe, is that the engine was very rich at the bottom, but too lean at the top.
Incidentally, I got my best mileage with the needles down one notch, and Derwat is having the same results with his.
My next test will likely be, floats at stock height, needles down one notch with 115 mains.
I don't think the needles can block the passage at full throttle, no matter what, unless you happen to have needles from a completely different carb. If they could, changing mains would have no affect, since if the needles were restricting top end fuel flow, then changing main size wouldn't do anything, and in effect the needles would be controlling top end too.
There has to be a point where the needles are, for all intents and purposes, out of the way.
What is interesting is that I hit the max top end at about 1/2 -2/3 throttle movement. After that there is a big dead spot.
I have another entire engine, new main and rod bearings, seals, gaskets, 1200cc barrels w/pistons, that I am trying to get around to in my shed. My cylinder head has been gone for 2 years waiting to be redone.
