Chaindrive MOD Update /PICS
  • Cobia
    • Jul 2007
    • 1587
    • Palm Beach County, Fl
    #46
    XSChop,
    That is one bad a$$ looking bike. You must let us know how it behaves when you roadtest it. Were you able to use the steering damper from the busa?
    1980G Standard, Restored
    Kerker 4 - 1
    850 Rear End Mod
    Automatic CCT
    1980GH Special, Restored
    '82 XJ1100 (Sold)
    • audijunky
      • Apr 2006
      • 707
      • VA
      #47
      Lookin sweet Chop, get some brakes and throttle and your set
      79 XS1100 modified standard
      straight pipe 4-2 exhaust
      Owned 83 Honda V65 Magna
      Owned 02 Vstar 650 classic
      owned 85 Honda Shadow VT 700C
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #48
        Answers
        Good question, I checked it out and you could change the xs11 wheel bearings to fit the Hayabusa axle. I have a bracket design still programmed in the CNC to put 'Busa calipers on the XS11 forks....Talk about overkill....BTW This axle has only two pieces...A bolt and an axle nut, wheel removal is a breeze here too! The steering damper would be an easy tab weld-on to the xs frame but I am keeping it simple and probably won't add it.
        MDRNF
        79F.....Not Stock
          #49
          Wicked!
          Nuff said.
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            #50
            newer wheelbases
            With the stock 'Busa front end and Triumph rear, I measure the wheelbase to be 61.75". I installed the 2.75" Fork extenders to raise front end a little & clear the mufflers a little more (I thought the pedals were draggin')....this brought my wheelbase to 62.75"....Give or take an 1/8"....I can lean really low in the turns and the steering isn't as quick. I will adjust the extenders in the middle range and see if the muffler scrapes at all....So far, So Good....
            MDRNF
            79F.....Not Stock
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              #51
              last updates
              Been out ridin' this machine hard this weekend. I decided to swap my gold colored Busa forks for my billet-colored forks/brakes to keep the flat-black billet look. I will use the gold ones on my next build.
              More customizing to the front end, I am happy so far with the headlights, the lower one throws a long beam and the upper throws a wide for normal driving
              I welded a bracket together to mount to the stock alloy bracket by two bolts and installed some new style LED license plate lights.
              Installed new rear LED signals as well...
              Had the Triumph St. chaingaurd lying around, so threw it on....
              And to protect my hard work, I drilled out 2 opposite 10mm slots to mount a rear wheel lock
              Looking forward to tomorrow's commute .....Chop
              MDRNF
              79F.....Not Stock
              • Shappers
                • Sep 2006
                • 158
                • Helsinki, Finland
                #52
                That bike is really coming along great Chop....
                '84 Sport
                • audijunky
                  • Apr 2006
                  • 707
                  • VA
                  #53
                  **** HOT BRO
                  • spinalator
                    • 4
                    • Saskatchewan, Canada
                    #54
                    Sweet Hayseus that is incredible. I can't believe you guys and your fabrication skills!
                    • audijunky
                      • Apr 2006
                      • 707
                      • VA
                      #55
                      all I would suggest is adding some kind of asspad. the fiberglass seat pan looks to be a hemroid causing SOB!
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #56
                        Suggestion
                        Hey audi, my @$$ suggested it first....had to get my airbox done for this weekend, so next weekend I will knock ot the seat pad....Have any suggestions?
                        MDRNF
                        79F.....Not Stock
                          • 7818
                          A small piece of 8mm wetsuit material, followed by 1" of hard foam and 1/2" of soft foam. Glue together, shape, add black Nagahyde or leather and your good to go!. JMHS
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #58
                            wet suit
                            got a pic or a link Diver ray?
                            MDRNF
                            79F.....Not Stock
                            • 79XS11F
                              • 3563
                              • Ottawa, Ont. Canada
                              #59
                              Now THAT'S A tire !!! Looking good chop.
                              Rob
                              KEEP THE RUBBER SIDE DOWN
                              1978 XS1100E Modified
                              1978 XS500E
                              1979 XS1100F Restored
                              1981 Suzuki GS1100
                              1983 Suzuki GS750S Katana
                              1983 Honda CB900 Custom
                              • Da-Bubble
                                • Jun 2006
                                • 353
                                • Oklahoma City, OK
                                #60
                                Chop,
                                That looks awesome! We need to meet up and ride soon. I am a new dad so my carbs are still taken apart on my work bench. I'm hoping to put them back together tomorrow. Hopefully I'll get it right this time and we can ride! If not, I'm gonna be begging Mouse to fix it!
                                See Ya,
                                Scott
                                1979 XS11 Special (slightly modified)
                                dubbed the "Mad Mosquito"
                                MikesXs Pod Filters
                                MikesXs 35k Coils
                                8mm plug wires
                                42.5 Pilots 142.5 Mains
                                (Carb tune by GNEPIG Performance)
                                Kerker 4-into-1
                                Shaved emblems
                                Progressive frt springs lowered 1.5"
                                Progressive 11.5" rear shocks
                                Harley Dyna rear fender chopped
                                Custm side mt tag (apparently illegal)
                                Custom Dual Headlights
                                Lots of time and hard work.
