Chaindrive MOD Update /PICS
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Factory swingarm
    I have been searching for a (abundant/cheap) swingarm that can utilise the same stock shock mount locations as the xs11's to go with the Chaindrive and keep the cost to a minimum. I really like the ZRX swingarms but I have noticed that they are also sought after by CBX afficianado's and other Kawasaki Tweekers. Eventually I will find one and keep everyone posted....
    MDRNF
    79F.....Not Stock
    • 79XS11F
      • 3563
      • Ottawa, Ont. Canada
      Re: Factory swingarm
      A straight switch out swingarm would save me a bunch of time and effort that's for sure.
      Rob
      KEEP THE RUBBER SIDE DOWN
      1978 XS1100E Modified
      1978 XS500E
      1979 XS1100F Restored
      1981 Suzuki GS1100
      1983 Suzuki GS750S Katana
      1983 Honda CB900 Custom
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        bolt on swingarm
        May be onto somethin. got an email back from a KZ owner....9 inches between pivots......and steel, so shock tabs can be welded easy
        MDRNF
        79F.....Not Stock
        • 79XS11F
          • 3563
          Re: bolt on swingarm
          Do you mean like off early 1980s KZ1000s and perhaps GPZ 1100s?
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            yeppers
            I have actually seen GPZ swingarms put on the xs11 somewhere on this site.
            MDRNF
            79F.....Not Stock
            • AlanB
              • Oct 2006
              • 705
              • Scotland
              Hi Guys,
              I think that I have an arm from a Z1000J (UK model?) hanging on a hook in the shop right next to an XS11 arm.
              I can do some pics and measurement in the morning......
              AlanB
              If it ain't broke, modify it!
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                z1000 j
                if it's early model then YEAH....big help....also measure the pivot bolt diameter if you can...thanks, chop
                MDRNF
                79F.....Not Stock
                • AlanB
                  • Oct 2006
                  • 705
                  • Scotland
                  Hi Chop,
                  Will sort it out tomorrow.
                  AlanB
                  • Dennyz
                    • 1151
                    • Olympia, Washington
                    Chop,
                    Where are you putting the battery?
                    DZ
                    Vyger, 'F'
                    "The Special", 'SF'
                    '08 FJR1300
                    • 79XS11F
                      • 3563
                      How more difficult would it be to go BELT drive??
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • AlanB
                        • Oct 2006
                        • 705
                        • Scotland
                        Hi Chop,
                        Finally got to it....... This arm is fairly sturdy looking; main tubes are 42mm. This one has a home-brewed brace added; Just ask if you want a pic........
                        Pivot is 16mm diameter... pivot tube is 38mm O/D and 234mm long..... about 9 1/4"
                        From the center of the pivot to the middle of the slot for the spindle is around 500mm; 19 3/4"
                        Center of pivot to shock bolt is 460mm; 18 1/8"
                        The wheel spindle is 20mm O/D, and 234mm shows between the adjuster plates (same as the pivot length....)
                        The inside faces of the shocks will be held 257mm apart; 10 1/16"
                        All the measurements are from eye-ball and steel tape, so don't hold me to the last mm..........
                        This was left over from a bike which we updated with a big-bore motor and modern running gear. We fitted an alloy arm from a GPZ1100 Unitracker. If my memory is OK, the pivot spindle diameter was the same, but we had to narrow the later arm across the pivot by around 15mm........
                        Hope some of this helps; keep up the work!
                        AlanB
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          xs11 swingarm shock distance
                          Since I no longer have a frame with the shock studs, what is the xs11's shock separation on the swingarm (or frame should be same). If it is close then it would be worth conjuring up the spacers needed to mount the z1 swingarm to the xs11. The difficulty I see here is that the z1 pivot bearings need to have an I.D. of 25mm, so the custom 25mm shaft can be inserted that has the 17mm recessed holes for the stock xs11's swingarm pivot bolts......But I do like the fact that it is @9 inch width at pivots because it would be perfect for positioning a stock rear wheel and sprocket and also clearing the stock xs11 rear brake master (which is trivial)....I looked at a z1 swingarm (1980) on microfiche and it looks like the needle bearings are 22x28x16 which means that a 25x28 bearing (x2) would be needed for the swap.....Maybe a custom bronze bushing if these can't be procured......This is why I have always mentioned that a swingarm with a I.D. of 25mm (most newer ones are) is the ideal mate......
                          MDRNF
                          79F.....Not Stock
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            battery
                            Odyssey PC 545 fits perfectly in the rear cowl between the xs11 rear hanger tubes, just welded a battery box to fit in between. Shhhhhh.....got the donor sheet metal from some poor realtor's sign....
                            MDRNF
                            79F.....Not Stock
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              belt drive
                              that will be on my next hit list....
                              MDRNF
                              79F.....Not Stock
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                pic
                                Hey Alan a pic would be nice. member SCAPPOD emailed a link to ebay #120221484850. If the bearings could be changed (under dust caps) then we have a winner. We also still need to know the xs11 shock distance to see if it matches.....
                                MDRNF
                                79F.....Not Stock
