XS Block With Sleeves Removed
  • Dan Hodges
    Sensei of Internal Combustion
    • Sep 2004
    • 526
    • A garage in south St.Louis
    I previously stated that I had bought a spare cylinder block from Andreas for use as a proto-type to determine how big a bore the XS block would accomodate and still be streetable. I have removed the stock sleeves and the bare block is on the way to Advanced sleeves in Ohio for machining and installation of 3.275 O.D. sleeves that will accomodate 78 mm pistons which will fetch 1311cc's. This bore size will still leave a wall thickness of .102 which is ample for a street bike. With this sleeve you could go to a 79 mm bore but that would leave the sleeves at only .0825 thick, too thin for me. You could (might) go to the next larger sleeve which has an O.D. of 3.42 however with that one you would be unable to use the stock "O" rings at the bottom of the sleeves which could cause an oil control problem in a street bike. The 3.42 sleeve would also require a case clean up which requires disassembly of the bottom end and I don't want to go through that again, at least not now. In a drag race only application the 3.42 sleeve would work but for a street bike it would ultimately seep/weep oil. For my application, the 3.275 O.D. sleeve will work out nicely. Last winter as some of you know I put a Wiseco 1179 kit in my Special and wish now I had gone the after market sleeve route but at time I had been told that the XS block would not accomodate larger replacement sleeves however that information was bogus. I had also been told by Yamaha tech in California and by the Yamaha dealer in St. Louis that the stock sleeves could only be removed by boring them out but that was also bogus as 45 minutes in an oven @ 450 degrees was all it took for them to slide out on their own just like my old FJ. Of course a 78 mm bore requires custom pistons and a one off head gasket but Wiseco, J&E and some others will make anything you want. I'm actually more than a little surprised that the stock XS block will accomodate these larger sleeves because of all the misinformation I have gotten regarding this modification however I shouldn't be as the XS was over engineered form the git go. The most diffulcult part of this whole deal will be making myself a base gasket but then again I might be able to trim up a stock one to make it fit, I can only hope. Thirteen hundred and eleven cc's, sounds good to me.
  • 81xsproject
    • 3185
    • Fortuna, CA
    Wow, Dan...you never cease to amaze me. I am absolutely BEGGING you to deliver some Dyno results on this soon to beast!
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
      Hey Dan,
      If this is going into your recent 1179 engine, I'm sure there are some folks on here that would be willing to take your 1179 kit parts off your hands. And folks can get the required head gasket and new rings from Cometic/Wiseco as needed. You would be the one to tell whether it's okay to use the wrist pins that come with the kit vs. getting new ones?? Looking forward to seeing the finalized project, and a list of any other mods added to this, like cams and such!?
      • andreashweiss
        • 951
        I have one cylinder block in the parts pile with or without stock pistons and rings if anybody needs one. Off a 81 sh xs1100. Could be used as is needs no repair, piston and rings have plenty of life left. andreas
          Base gaskets are easy... I make mine all the time. The only one I don't make is the head gasket for obvious reasons. Just remember that the little thin metal strip that you see there on the bottom in the cam chain galley doesn't have to be incorporated into the gasket. Just cut out the gasket like it's not even there.
          I too found out that the sleeves will come right out... it's just that I hadn't wanted them to! lol. I was trying to bake some high temp paint on my cylinders. I set them down in the oven resting on the bottom of the sleeves. After a while I heard a CRASH!! and went and saw all the sleeves had popped out and the block was laying on the oven grill.
          • 81xsproject
            • 3185
            • Fortuna, CA
            Another thing I would like to know is how much it costs to get the custom sleeves and pistons.
            '81 XS1100 SH
            Sep. 12th 2015
            RIP
            • Dan Hodges
              • Sep 2004
              • 526
              Cost
              The block and sleeve work at Advanced Sleeves on a one of a kind deal like mine is strictly done on a cost of the time it takes to do the work. It cost $200.00 to bore and hone my present block for the 74 mm Wiseco pistons in my 1179 combination but I have no idea what this custom combination will be and I didn't press Mike for a price. Custom one off size pistons are about $50.00 per piston more than the off the shelve models if you get them from Wiseco.
              • Dan Hodges
                • Sep 2004
                • 526
                Gaskets
                My sleeves came out pretty much the same way but Donelson told me again today that they have seen some that have to be bored out but I'm not sure. I have half a dozen new stock base gaskets and the cylinder hole measures about 3 1/4 inches and so I'm sure I can trim it a little and make it fit.
                • Dan Hodges
                  • Sep 2004
                  • 526
                  Too Much Time On My Hands
                  Hey Dan,
                  The 1179 block and piston combo is not for sale however I will be using the same Mega-Cycle cams I'm using in the 1179 but with a different intake center line setting in the larger motor. Last winter I posted some pictures of the head which went onto the 1179 which was ported by Patrick Racing and I will be using this same head again. Basically the 1311 will be the same deal as the 1179 but with more cubic inches and compression. The new clutch with the stiffer springs seems to work well and as soon as I get some decent weather I'll take it back to Widman for another dyno deal. I should have known better than to use that spook oil (synthetic) but you learn from your mistakes and all is well that ends well.
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    Dan,
                    If you have not gotten all your parts assembled yet, how about a picture of everything laid out and ready for assembly.
                    Mike Giroir
                    79 XS-1100 Special
                    • Dennyz
                      • 1151
                      • Olympia, Washington
                      Looking at the Wiseco site, I notice the FJ1200 big bore kit uses a 78mm piston. Any chance it might work?
                      DZ
                      Vyger, 'F'
                      "The Special", 'SF'
                      '08 FJR1300
                      • 81xsproject
                        • 3185
                        • Fortuna, CA
                        Other than the size of the wrist pins, what else would need to be the same?
                        '81 XS1100 SH
                        Sep. 12th 2015
                        RIP
                        • mro
                          • 4276
                          • Hayward, California
                          Other than
                          Maybe piston height,
                          center of rist pin to top of dome?
                          • AlanB
                            • Oct 2006
                            • 705
                            • Scotland
                            Cut-outs for the valves?........ FJ is a four-valve.........
                            AlanB
                            If it ain't broke, modify it!
                            • TADracer
                              • 1417
                              Increased Compression?
                              Dan, something I thought of last night. If the displacement is goiing up to 1311 and it is all done in the cylinders, will this not raise the compression ratio up in the neighborhood of 11:1? Or, are you compensating for some of this with your piston/deck height?
                              What other things must you do to take advantage of the increased compression?
                              Mike Giroir
                              79 XS-1100 Special
