XS Block With Sleeves Removed
  • Dennyz
    • 1151
    • Olympia, Washington
    CR
    My calculation indicate the CR would be 10.95:1 with a '78/'79 head. This is great. Motorcycles can run 11:1 on pump premium with no problems (not sure about 2 up cruisers). I am using the later head so would expect a little less CR. I was considering head work to get the CR up, now I just need to punch it out to 1311.
    I got so excited when I read this tread, I went out and heated a set of cylinder up in my powder coat oven to pull the old sleeves out. Worked like a champ. I think I will glass bead them and powder coat them a satin black. Get them ready for new sleeves.
    Before I spend the $$ on the sleeve work, I need to learn more about piston option.
    DZ
    Vyger, 'F'
    "The Special", 'SF'
    '08 FJR1300
    • 81xsproject
      • 3185
      • Fortuna, CA
      I am with you Denny. This thread totally changed my future rebuild scenario.
      '81 XS1100 SH
      Sep. 12th 2015
      RIP
        Originally posted by 81xsproject
        Thread totally changed my future rebuild scenario.
        See what you've started now, Dan!
        • Dan Hodges
          Sensei of Internal Combustion
          • Sep 2004
          • 526
          • A garage in south St.Louis
          11:1 Compression
          All things are possible with the Eleven but a word to the wise, 11:1 compression is a little high for an air cooled street motor unless you use an intake cam with an event angle different from the stock cams. New bikes are water cooled and the combustion chamber is shaped differently than that of the Eleven and engines of that era and can tolerate more compression without detonation problems. A pent roofed combustion chamber with a centrally located spark plug will tolorate more compression before detonation than a combustion chamber like that of the Eleven. Actually pumping compression is the determining factor and 160-170 pounds max is all it will tolerate safely and static compression and intake cam phasing will determine this. Why am I telling you guy's all this stuff anyway, I must be getting easy in my old age. Of course I haven't told you everything, of course!
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            That's a big CC increase and a Worthy project for the 11. Myself I would ebb on the safe side with the compression ratio. Given the amount of time and dollars you will have into the project it would be a shame to have an unexpected issue when completed. Your going to get a big power increase just from the CC increase alone so why push it with high compression numbers.
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
            • mro
              • 4276
              • Hayward, California
              Change the lobe center of the intake?...
              then degree the cams?
              mro
              Been too long ago to remember engine mods other than basics.
              A 19 percent in C.I. is pretty radical in it's self, but each change demands another at this level and generally requires mucho mulla at a good machine shop. Head will need some work as well as the exhaust. Will probably want the "early" XS TCI and timing parts too. CC head/cylinders, and at least balance the pistons and rods....
              • alaskey2
                • Apr 2014
                • 271
                • 60940
                This thread needs closure!!! What happened here?!?!? We need more ideas like this and less threads about how to restore your windjammer fairing.
                78 E
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  I agree !
                  I had the chance to buy a custom built 1396 cc. XS11 years ago for $1000 and I passed as I thought the guy was selling something that could not be run on the street. It had not been run in years just sitting in his shop. When the guy that built it found out it was for sale and collecting dust he went and yelled at the owner, bought it and that's the last I heard. I believe it was an LG and remember the lowered custom leather seat with bright red suede flames in the middle all covered in thick dust.
                  He owned the Excaliber Motor Co. that built custom cars but had fallen do to EPA or something like, they wanted him to crash so many per for safety.
                  What would you do to the trans in a beasty like this so as not to shear dogs off ?
                  76 XS650 C ROADSTER
                  80 XS650 G Special II
                  https://ibb.co/album/icbGgF
                  80 XS 1100 SG
                  81 XS 1100LH/SH DARKHORSE
                  https://tinyurl.com/k6nzvtw
                  AKA; Don'e, UD, Unca Don'e
                  • James England
                    • 3039
                    • North of England
                    What actually is the effect of these mods then? The bike is 95bhp standard. What wouldd it be after the mods?
                      • 3957
                      James- If you read Dan's threads, he never attained much more than 100+ horses with all the money he spent on head jobs, etc. The only guy besides John I have seen with those numbers was Brian, whom has the youtube video of the 107 hp run on the dyno. Oddly enough, he did not do an overbore, but instead went with racing cams, lightened/balanced crank, etc.
