Who Wants A Bolt-on Chaindrive And Fat Tire?
  • thanks man im new to bikes so need all the info I could get what size would the spacers need to be and what I do for sprocket and brakes on the ducati or triumph rim
    • Chain Drive conversion parts
      XSchop, I saw your awesome chain drive conversion parts on a guys webpage in Canada doing a modified XS1100 project. When will you be making more of the units and will they still be $350. I can handle getting the other parts required. I am a motorcycle head porter and machinist by trade with 14 years experience working for first Superbike Mike Engineering in FL and Lee Shierts of Lee's Performance in NC. I have always loved retro aircooled fours and the XS motor is like a bigger better KZ900/1000 to me only with a lighter crank arrangement and a way sweeter combustion chamber from the factory. Everything about it is cool except for the shaft drive limiting the mounting of modern rubber. Is this the only way of contacting you or do you have a website? I just got my 78 XS1100E so I don't need the conversion part immediately. Look forward to hearing from you. Sincerely, Mike Barron
      79 XS1100 "Velvet Hammer"
      Progressive springs, MAC 4-1 with modified glass pack thrush 2" baffle inside megaphone, 80 carbs with Dynojet kit and K&N's, Ported & Polished head soon (it's what I do)
      87 FZ700/ YZR500 replica in progress
      93 GS500/ 851cc stroker superlight in progress
      • Originally posted by mrbisbob View Post
        Hey Mike and Welcome to the board ... You might want to try a private message to xschop.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • Just for the purpose of reviving an old thread, will this middle drive also work on an XJ650? Just curious. You mentioned it working on a XS/XJ750, and I have an XJ650 and would consider this item as a good investment... Only since 125mph from the stock gearing gets boring after a while...
          • xj750
            have secca750 final drive for the price of postage it will not work for xs1100
            bill hane
            • Bill, you have a PM!
              Also, after just looking at the two, I answered my own question, the drives between my xs11 and xj650 are most definately not the same! Although it would be sweet to have a chain drive on both... Now my only decision is do I buy the xs11 one from you, or machine my own? Hmmm... A better question is are you still making these?
              • Bolt-On Chaindrives
                I will make a run of these in a few weeks.Someone with an XS850 wants one bad..... Hit me up if interested. I'll need a middle drive shaft from you and the factory inner bearing C-Clip and outter bearing locknut that is in your housing.....Chop
                MDRNF
                79F.....Not Stock
                • Interested in middle drive
                  Brand new to the bike, haven't even got it in the garage yet, but I'm picking up a 1980 XS1100 Special from a guy I work with for free. He's neglected it and it needs brakes (pads rusted to rotors), carbs cleaned and tires. This will be my first real chopper project and would absolutely love to do a chain drive wide tire.
                  Has the run been made yet because I'd love to get my middle unit changed.
                  • Me Too
                    I have a spare engine I can pull the middle drive off and send it, Are you finished the run yet? thx Rick
                    I May Be Crazy, But I Have A Good Time.
                    Northern Gypsy - 2010 Kawasaki Concours 14 ABS - Daily rider
                    • 2500 mile inpection and 14T sprocket install
                      Scroll down to the 2nd post. I didn't even have to change out the sealed bearings, swappped on a new 14T sprocket and been on a long trek today.... 750 FD gears are back!
                      http://www.vmaxforum.net/showthread.php?t=7813&page=8
                      MDRNF
                      79F.....Not Stock
                      • Tried to edit the last reply....
                        After roughly 2500 miles there is no play/looseness in the sealed bearings. I was surprised of how little wear was on the 13T....
                        I stuck on a 14T and now I'm back to 38-40 MPGs...
                        The splines are as new as when I installed it....
                        I had previously ground out about 3mm of the case near the sprocket for the 14T on Recommendation from PGGG .....Judging by the clearance I think a 15T is not a problem...But unnecessary since I'm as high geared as I want to be....
                        MDRNF
                        79F.....Not Stock
                        • Sweet work
                          That's some nice work Chop keep posting about how things progress, I'm majorly interested and I doubt there's a soul on here who isn't.
                          • XS11 Chain
                            PM me if interested. I will only make a run of 3 or more. It actually is more cost effective because I get the billet on discount that way. I am ramping up and getting ready to design and build a Bolt-on chaindrive for the Vmax and will be busy this summer
                            The big question for the Vmax conversion is answered now. Just a simple sealed outter bearing can be used with longevity.
                            MDRNF
                            79F.....Not Stock
                            • i'd be interested still in the chaindrive conversion. I plan to build my own swingarm so all i need is the conversion. I still plan on keeping the springs though. So yeah whats the price on just the conversion.
                              Yes it's a damn nice bike, yes it's in REALLY good condition, yes it would be a shame to chop it, BUT damn how cool would it look with ape hangers?
                              • Pm
                                PM sent.
                                These are the last ones I will ever make....chop
                                MDRNF
                                79F.....Not Stock
