This site will be temporarily offline this Friday April 18th from approximately 5pm PST (UTC-7), for a few hours or less (hopefully) for upgrades. See this post in Forum Announcements for more info.
I have an extra complete set of solid aluminum mounts if anyone is interested, if there is big enough interest I can make more Probly about $55 would be worth my time and material....pm me...chop
MDRNF
79F.....Not Stock
These do take out the flex of the frame under hard acceleration and cornering...and I don't notice much more vibration than the old rubber ones (maybe because they were old)....
MDRNF
79F.....Not Stock
Would you mind posting that diagram that they are sitting on, so folks might be able to utilize your measurements IF they wanted to make their own??
79SF "The Teacher" . . .basket case! History shows again and again,
plagiarized from the U.K. site....Just don't ask me to post my chain drive conversion schematic....For material use 1.5" round stock...have fun....chop
MDRNF
79F.....Not Stock
Acta Non Verba
Because of the way the motor goes into the frame, a simple poly bush does not work; You need a steel centre right through the bush- Same idea as the rubbers which yamaha fitted.
If there is only poly, the frame will "pinch" as the bolts are tightened. You need something like this:-
I saw those too (very nice work). I made a rear bottom set (solid)for my latest project to keep the sprocket steady in relation to the frame. Question, why didn't you extend the poly all the way to the end of the inner metal mount?
MDRNF
79F.....Not Stock
