Solid alloy mounts
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    Solid alloy mounts
    I have an extra complete set of solid aluminum mounts if anyone is interested, if there is big enough interest I can make more Probly about $55 would be worth my time and material....pm me...chop
    MDRNF
    79F.....Not Stock
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    frameflex
    These do take out the flex of the frame under hard acceleration and cornering...and I don't notice much more vibration than the old rubber ones (maybe because they were old)....
    MDRNF
    79F.....Not Stock
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      they make it handle better?
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • dale_1
        • 275
        • Jacksonville, TX
        mounts
        do they increase the frame harmonics???
        Mark A. Guthrie TSgt USAF (ret)
        S&M Comp. Serv. Inc. V.P.
        1981 XS11SH XCaliber
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          handling
          the motor acts as a stressed member after you install these, gets rid of the sponginess of the xs frame...chop
          MDRNF
          79F.....Not Stock
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            PMed you
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
              Hey Chop,
              Would you mind posting that diagram that they are sitting on, so folks might be able to utilize your measurements IF they wanted to make their own??
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                ask and you shall recieve
                plagiarized from the U.K. site....Just don't ask me to post my chain drive conversion schematic....For material use 1.5" round stock...have fun....chop
                MDRNF
                79F.....Not Stock
                • Mike F
                  • 99
                  • Amesbury (next to Stonehenge)
                  Glad to see you using the drawing - I should have done one in imperial as well. -
                  I know we have inches as well over here in the U.K. but I find metric easier to measure.
                  Keep revving
                  Mike F
                  Mike Farnworth
                  XS1100 E & XS1100 Sport Project
                  • HobbyMan
                    MeatHead Idiot "GURU"
                    • 1801
                    • Colleyville, TX
                    Why did yamaha use rubber to begin with?
                    Acta Non Verba
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      can some make them out of polyurathane sway bar material?
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        That's what I'm hoping to do someday
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                        • AlanB
                          • Oct 2006
                          • 705
                          • Scotland
                          Hi Guys,
                          Because of the way the motor goes into the frame, a simple poly bush does not work; You need a steel centre right through the bush- Same idea as the rubbers which yamaha fitted.
                          If there is only poly, the frame will "pinch" as the bolts are tightened. You need something like this:-
                          More info at-
                          Hope this helps!
                          AlanB
                          If it ain't broke, modify it!
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            poly
                            I saw those too (very nice work). I made a rear bottom set (solid)for my latest project to keep the sprocket steady in relation to the frame. Question, why didn't you extend the poly all the way to the end of the inner metal mount?
                            MDRNF
                            79F.....Not Stock
                            • chopper
                              • Nov 2002
                              • 167
                              • scotland
                              To kill secondary vibration I'd imagine, as the XS was always a long distance mile eater.
                              mick
                              xs1.1s(x2)
                              gsxr1100(1127)
                              gsx1100g(x2)
                              trophy900
                              bonneville750
                              http://www.tonyfoale.com/
